new guy... headlight motor question
Old Nov 20, 2009 | 11:00 AM
kern676's Avatar
Car: 1989 Pontiac Firebird
Engine: LO3 305cid V8
Transmission: 5 speed
Axle/Gears: 3.08 std
ok, so im new here and i have an 89 firebird. the problem i have is that both of the headlights pop up very smoothly, but neither go down. searching these forums ive found that its probably the isolation relay thats the issue, and even gotten the part number. the ploblem im having, tho, is where to get a new one to replace it. if anyone knows of where i can get it or maybe a way to cross-reference it to another relay, any help would be appreciated. thanks!
Old Nov 20, 2009 | 02:52 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Re: new guy... headlight motor question
you should check on jegs, under the ignition and electrical they have lots of stuff from painless for wiring.
also you might want to check all the connections to the motor because it it goes up smooth its not a bad motor, so it might be a loose wire.
Old Nov 20, 2009 | 06:03 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
it definitely sounds like your headlight module is going bad (or is bad). Check it out and pop it open, you'll see the relay (its in a clear case) inside and I bet some of those wires are bad/disconnected. The headlight module is located at the left of the brake booster (its between the brake booster and wiper motor on the firewall). It has 2 sets of wires going to it...
Old Nov 21, 2009 | 08:15 AM
kern676's Avatar
so you think its more of a wiring issue than a bad relay?
Old Nov 22, 2009 | 11:04 AM
HCR13's Avatar
Car: 1987 Trans Am
I think its your module which contains the relay. Did you find it?
Old Nov 24, 2009 | 07:23 AM
kern676's Avatar
yea, i went out to the car yesterday and pulled the module... the relay was good but the board had definitely gotten wet at one point and some connections were corroded. my friend with an 87 z28 who deals with computers and mother boards everyday looked it over, said it didnt look good. so a new one is on order.
Old Nov 24, 2009 | 02:27 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, they can be had at any junkyard with a 3rd gen Firebird. Before you get the donor, make sure its the same headlight motors. GM used 2 types. A 3-wire and a 2-wire. I don't remember what years had what. But if your headlight motors only have 2-wires then get the module from the car with a 2-wire motor...
Old Dec 3, 2009 | 08:16 PM
kern676's Avatar
ok, so i switched the module out with a new unit, the proper one for my 89, and the problem is still there.... now what?
Old Dec 3, 2009 | 09:15 PM
HCR13's Avatar
Car: 1987 Trans Am
still same issue? wont go down? To make sure its not a wiring issue, test the pigtails that the headlight motors plug into, the one attached to the car (wiring harness). When the headlights go up one wire should be positive and the other negative, when the headlights go down (or supposed to) those polarities should switch. If that is correct then the headlight module is working like normal and it would be the motors themselves with the issue...
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
