Positive battery cable question.
What is the black "bulb" that branches off of the positive battery cable for? It has 20 written on it. I broke off the wire at the base of the bulb, and GM no longer sells the positive battery cable. Thanks for any and all help!!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Able With Cable
Yes there is a fuse there 20 amps.
You can attach an additional fused wire to the battery using a ring terminal.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
Re: Able With Cable
mine was for my fuse for fuel pump on my 3.1 rs !
Re: Able With Cable
wow didnt know that was for the ecm too thanks again john !
