Rear battery breaker amps needed?
Old Nov 30, 2009 | 03:29 PM
flymikemc's Avatar
Car: Restoring 85 IROC-Z, 89 5.0 notch
Engine: to be 383
Transmission: T-5 and T-5
Axle/Gears: 3.27in IROC and 3.55 in mustang
I have relocated the main battery to the rear of the car. I was wondering if anyone knew what size breaker one would use to protect the power line running up to the engine? I don't want it to some how ground out and cause a fire. Does anyone know what size it should be? Any thoughts on the matter? I have been running too long with out one.
Old Nov 30, 2009 | 09:12 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Rear battery breaker amps needed?
I've never seen one used, just a cut off switch. The starter can easily draw a couple hundred amps. Doesn't mean they don't make them, maybe for a golf cart or fork lift.
Old Dec 4, 2009 | 11:25 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well the purpose of a fuse/circuit breaker ect is to protect the wires not the actual stuff there wired to. So what im trying to say is if you were going to get a fuse or a circuit breaker you would need to select it based on the gauge wire you used.
Old Dec 5, 2009 | 04:45 AM
flymikemc's Avatar
Engine: to be 383
I am just trying to protect against a short circuit fire. I used welders wire. I think it is 0/1 or something like that. Its about twice as thick as factory battery cable. Any idea what breaker that might use?
Old Dec 5, 2009 | 11:34 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
IDK wiring stuff--
Would the way to find out be :
Add all accesseries power used
Add this to cranking power used
Check alternator for max amps safely usable
Then that would be a starting point to try breakers??
Are you using 2 batts? I see you said "...main battery..."
Old Dec 5, 2009 | 06:24 PM
flymikemc's Avatar
Engine: to be 383
actually I am. I have a small one as a "booster" battery up front and a regular size one in the back. I have the small one isolated via a relay that I can turn on in hot traffic (electric fan) or when my engine gets really hot and needs a boost I can flip that one on and get some extra juice.
I don't know the cranking power used so I am at a bit of a loss. I guess I could try something like a 120amp fuse or something inline and see what happens. I just don't want it to be able to sit and arc and start welding stuff and cause a fire if it ever did short out somewhere. The small battery is isolated so I am not so worried about that one.
Old Dec 7, 2009 | 09:38 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Breaker 19
It makes a difference in cold weather.
If the car in question is a good weather car a starter can draw 250 amps.
In cold weather it’s much more.
A breaker with the current you require is too elaborate of a setup.
Use a fuse.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Dec 7, 2009 | 06:24 PM
Well without knowing truely what gauge it actually is i cant make a recomendation as to fuse or breaker size. I dont want to say one thing and hear your car burny up because it was sized incorrectly ya know what i mean. Although i will say that theres alot of people commenting about heavy draws like the starter but thats not really what you would base your fuse or breaker on. This is because a lot of things especially motors have a higher than normal draw on start up. However it only does this for a short period of time which is ok. For example you only supposed to crank a starter for 30 seconds max befor letting it cool or else it will burn up. This is because the current draw exceeds the motors maximum CONTINUOUS rating although it is fine for maximum intermittent. Same thing with even wires. A wire thats rated for 10 amps may do just fine passing 100 amps but for maybe no longer than 1 tenth of a second. Because of this fuses are rated for how quickly they will react. So again a slow blow fuse rated for 10 amps wont be blown by a 20 amp load if its duration is short. So not only do you need to get a fuse thats rated for your gauge wire but also something that reacts slowly to account for starting currents.
Old Dec 7, 2009 | 09:58 PM
flymikemc's Avatar
Engine: to be 383
Thanks for the info. I guess I will try like a 75 amp and see if it holds it.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kyleb24
Aug 15, 2015 08:24 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
