trying to rewire my running lamps/turn signal.
Old Dec 10, 2009 | 08:04 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I am rewiring the entire car, and I have everything sorted except for the running/turn signal system. I am overlooking the diagrams and when I pop on my headlight switch, i get only tailights, license plate lamp and rear corner markers.. my front fender side markers and front running lights do not work at all. and my blinker system doesnt work at all either..
I am looking over these diagrams and see the BROWN(BRN) wire coming from the headlight switch must be 12+ to all the lighting on the exterior of the car. but the front turn/running lights are a 3 wire bulb, brown, black and lt/dk blue.
so if the two bulbs are properly grounded , and get 12v from the brown wire, shouldnt it light up? or does the lt and dk blue wires need to be wired in as well?
the lt and dk blue wires run both straight to the turn/hazard switch. and YEL and DK green control the rear turn signals.
can I get any insight? the turn/hazard switch is getting proper 12+volts through both the flasher and hazard relays.
Old Dec 11, 2009 | 11:48 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: trying to rewire my running lamps/turn signal.
I can tell you from memory the side markers are wired in series with the front running lights. The current actually reverses when you put on the turn signals depending on whether or not your parking lights are on. The front 3-wire bulb is the only one hooked directly to a ground. The wire coming off the side of the bulb socket.
Old Dec 14, 2009 | 09:10 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
You really should just wire it as the factory schematic says. Its a fairly complicated system with how it works. Rather than try to re-engineer it just rewire it as it was.
Old Dec 14, 2009 | 09:51 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
thats for a firebird, so ignore the headlight pop up stuff
Old Dec 14, 2009 | 11:08 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks, I got it all figured out, then when I put my dashboard all back together, they all just come on without blinking, except the front fender signals, they are off on both sides. any indicator what that means?
with the running lights on, all my lights are on, but when I turn on my blinkers, the two front fender lights go off..
I probably disrupted a connection when I put my dash back in..
Old Dec 17, 2009 | 07:34 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
your running lights are your dim lights right?, because im having a similer problem, my turn signals don't work and neither does my low beams or dims, i can turn them on but i only get my dash lights but when i turn on my brights i have my headlights...so is this the same problem or atleast similer?
Old Dec 17, 2009 | 08:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
No, I found out my problem was my battery was so dead, it wasnt kicking the flasher on lol.
Old Dec 17, 2009 | 08:22 PM
Engine: L31 350
well crap
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
