92 Camaro Odometer/Trip odometer quit
Old Dec 17, 2009 | 12:27 AM
PINK16's Avatar
I have a 92 Camaro, V8 305, Automatic. Car is clean and all original. The odometer is no longer working. The trip odometer is not working either. All other gauges work, including the speedo and tach. I've attempted searches on here, but my question is: Does this year have the small gears that drive or work off each other, and possibly the teeth are stripped causing both not to count. I know it does not have a cable. Please any advice for me to repair this problem. Odometer is stuck on 88,760.
If you push the trip odometer, and let it release quickly, it will sometimes cause the 1/10 mile last digit to jump, but is stuck between 5 and 6. This is why I think it may be a stuck or stripped gear.
Old Dec 17, 2009 | 08:26 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Ode To A Meter
Correct.
The speedometer/odometer assembly is replaced as a unit.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Dec 17, 2009 | 08:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Ode To A Meter
Isn't there a write up on here somewhere about a fix for the odometer/trip meter?
*edit* Found it ... Maybe it'll help:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
Old Dec 18, 2009 | 03:18 PM
PINK16's Avatar
Re: Ode To A Meter
That fix is for 82-89?? with the cable drive. Would it be the same for the 92? and if neither my trip or odometer is working, would that mean that the upper J clips may be broke as well or does the trip meter being broke affect the actual odometer. Thanks for any and all input.
Old Dec 19, 2009 | 09:18 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Ode To A Meter
I've had the whole cluster fry on me and replacved with a NEW one. sometimes the speed wouldn't work (which is why the odometers wont go) so I had the speed sensor replaced. no problems now.
Old Dec 19, 2009 | 12:50 PM
PINK16's Avatar
Re: Ode To A Meter
I have no problems with the speedometer, or the tach. Only the odometer and trip. Do I need to drop the steering column in order to remove the entire panel safely. And anything to "watch out" for. Would hate to mess something else up in this process. Thanks for all the replies
Old Jan 16, 2010 | 10:53 AM
PINK16's Avatar
Re: Ode To A Meter
Well finally got it apart. There are no J hooks on the back of the assembly. Where is the speed sensor located? what does it look like? Can I just replace the small motor that turns the odometer that has 4 small wires coming out the back of it?? Got it all apart, what should be my next step. Can send a pic by cell phone. My number is 972 742 4617. Call me, PM me, I need help please. Jay E
Old Jan 16, 2010 | 11:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Ode To A Meter
Tail shaft of the trans. IIRC, yellow and purple wires.
JamesC
Old Jan 16, 2010 | 08:02 PM
PINK16's Avatar
Re: Ode To A Meter
Would the speedometer still work if the speed sensor was bad. The speedometer always works, except about a year ago it jumped from 0-40 for a couple of miles but then straightened itself out. Do you suggest I install a new speed sensor, If so should I go ahead and reinstall the gauge cluster. Thanks to all.
Old Jan 17, 2010 | 05:11 PM
92 Camaro's Avatar
Re: Ode To A Meter
wait, does any connection look bad on the cluster?
Old Jan 18, 2010 | 11:55 AM
PINK16's Avatar
Re: Ode To A Meter
Don't really know what a bad connection looks like, but there are no dark/burnt spots on the entire cluster. I can turn the small gear on the back of the small motor on the cluster and the odometer and trip will increase. This problem started by a jumping speedometer for a couple of miles. It would then not count the miles. Then straightened itself out. Then a couple weeks later the odometer would count sometimes and sometimes not. Usually would count the first 1-2 miles of driving then stop. Now it won't ever count mileage, but the speedometer always works?? Just trying to get those "little" things fixed. Car is in great shape, other than peeling paint on the hood and hatch deck lid. Runs great. Always clean oil after 3000 miles. Doesn't leak a drop of fluid from eng or transmission. Does have a leak around the back part of the t-tops that I can't find(rear pass seat gets wet only). And the drivers pw is slow and then overheats and stops. but the odometer is driving me crazy.
Old Jan 18, 2010 | 02:34 PM
NINÅ's Avatar
Transmission: 765R4
Ode To A Meter
No.
Because the speedometer “
always works” the VSS is good.
Happy Racing!
Old Jan 20, 2010 | 08:11 PM
PINK16's Avatar
Re: Ode To A Meter
Any other ideas? Desperately need help here. Any way to "jump" the small electric motor that turns the gear for the odometer, just to check the motor. Should I start tracing wires back to the vss? Thanks
Old Jan 23, 2010 | 07:03 PM
PINK16's Avatar
Re: Ode To A Meter
Well, reassembled everything, and with the same result. No odometer, no trip. Any suggestions??
Old Mar 24, 2010 | 01:54 PM
Mike McArthur's Avatar
Re: 92 Camaro Odometer/Trip odometer quit
I have the exact same problem with my 87 GTA. Have you figured anything out?
Old Mar 24, 2010 | 09:59 PM
PINK16's Avatar
No, still have the same problem. Don't know what else to do. Think the small electric motor may have gone out. Still no prob with the speedometer, only the odometer and trip. Have any ideas, would love to hear them. Drive it one day a week, need to sell it. It is a third car for me, cant drive 2 cars at one time. Thanks for all the replies, guys and girls
Old Mar 25, 2010 | 07:12 AM
I sent an e mail to Mr Whizard asking if they can fix it. They said there is a history of problems with this unit and they would have to look at it. They said it would cost $179.00 including shipping both ways if they can repair it and it would take two weeks. I'm going to ask one other place and then I think I'll give them a shot. I'll let you know what happens. This is the link to the site. http://www.mrwhizard.com
Old Mar 25, 2010 | 07:35 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
I have the same problem on my 88 GTA. I have been advised on this board to replace the speedo.
Old Mar 25, 2010 | 01:47 PM
I called Southern Autotronics today and he knew exactly what I was talking about. He said it is either the motor or the circuit board and would be either $150, or $205 depending on what it is. I am shipping mine today. Here is the web address. http://www.instrumentclusters.com
Old Mar 30, 2010 | 08:09 PM
zero_g's Avatar
I have the exact same issue on my 92.. Pink16 and Mike did you get your fixed?? Curious on who you used and if you recommend...
Thanks!
Bobby
Old Apr 25, 2010 | 05:55 PM
PINK16's Avatar
Have not figured mine out?? Hate to spend more money on the car. I need to sell it. i think it is the small motor, cause the last few times it worked, it would only count about a half a mile and stop in the mornings, and the same on my way home from work. Sort of like an overheating power window: works slowly and then over heats and quits. How can i test this little motor that turns the odometer, and where can i get a replacement. thanks again
Old Apr 25, 2010 | 06:16 PM
I sent mine to Southern Electronics about two weeks ago. Still waiting for it to be fixed. I called the other day to check and he had not got to it yet. Hopefully it will be in the next few days as I am also selling this car. Hard to sell a low mile car without the odometer working.
Old Apr 25, 2010 | 07:56 PM
zero_g's Avatar
Let us know when you get it back and if your satisfied. My car also has an intermittent spedometer as well as the no odometer issue. Anyone know if that is part of the issue or if can't be related to the cluster due to it being driven by something else? I would like to kill 2 birds with 1 stone if I can.
Old May 5, 2010 | 11:01 AM
I received my repaired cluster from Southern Electronics yesterday. Works like new and cost $215.00. I am very satisfied with the repair and the service. It took about four weeks total to get it done. They include free shipping both ways. There is a shipping label you print out and then send it by UPS. I'm glad to finally have a working odometer again.
Old May 6, 2010 | 06:51 AM
zero_g's Avatar
Thanks Mike for letting us know how it went. A month is a long time during nice weather. I will have to plan a repair month and take care of a bunch of stuff when it is down for service..
Old May 5, 2011 | 11:40 AM
Jim7463's Avatar
Car: '91 RS Coupe
Re: Ode To A Meter
I'm having a similar problem with my '91 RS. A couple of weeks ago the odo and trip odo just stopped. Have had an intermittent problem in the past with the speedometer quitting on me, but eventually it started working again. In the meantime, I took the cluster out of the dashboard (it does help to drop the steering column) and checked the pc board connectors. They look ok, but wonder if unseen wear is the culprit. My trip odo has occasionally not fully reset when I reset it after gassing up. I wonder if replacing the instrument cluster circuit board would help, if that's even possible. I too am open for suggestions. Thanks!
Old May 5, 2011 | 11:45 AM
Jim7463's Avatar
Car: '91 RS Coupe
My only problem with sending my instrument cluster in for repair is that my Camaro is my only transport. I suppose I could drive "blind" until I get it back, as long as I fill up the tank and keep track of my mileage the old fashioned way ) Not sure if the electrical system might be adversely affected. Ideas??
Old May 5, 2011 | 11:58 AM
Jim7463's Avatar
Car: '91 RS Coupe
Am taking your advice, Mike, and contacting Southern Electronics to see what they can offer. Thanks for the heads up!
Old Jul 2, 2011 | 12:03 PM
Colemaro's Avatar
Well I am soo disgusted with this cars electrical problems ,(91 Z28) , that I am going to sell it at a loss and buy a mustang. They dont handel as well, but they don't have all the " might be this , might be that", GM electrical problems either.
Old Jul 2, 2011 | 02:52 PM
Jim7463's Avatar
Car: '91 RS Coupe
Hi Colemaro. What kinds of problems? I've had numerous with my '91 RS, but I always manage to find a way to correct them. Just got my a/c fixed by way of a reman compressor. COLD air again!
Old Jul 3, 2011 | 11:42 AM
Colemaro's Avatar
Well, as usual the tach is toast, Speedo works when it wants to, cruise doesn't work, switches for mirroros /doorlocks bad,Headlights dont have brights, the sensors for the fans, and the thing sometimes doesn't want to start. Other small mechanical things that I have had to replace, I guess thats a given for wear and tear. I don't want to go in the hole that bad just to drive this car. It is my third "Z" and it is the worst of the lot. They seem to just get worse with the more modern they are. I liked it because it is a southern car and has almost zero rust. If I can get 1500 for it I will let it go to someone. Never owned a mustang, but few of my freiends have and they were pleased. Maybe it's time for a change.
Old Jul 15, 2011 | 11:33 AM
Jim7463's Avatar
Car: '91 RS Coupe
There's a wesite called instrumentclusters.com that I was referred to by another 3rd Gen member. I have not sent mine in yet, but I understand they'll make your instrument cluster like new. My cruise is also on the fritz, but isn't a priority. My driver door mirror still works, passenger side is fixed. Headlights with no brights sounds like a bad contact or the switch in the steering column is bad. I was able to sort of fix mine. You are right, the more modern Camaros have more stuff that can fail. I look at this way - when I bought mine in Dec '95, I told myself I was going to keep it until it fell apart. She's lasted almost 16 years, thanks mainly to taking simple care of the important stuff - oil, tire pressure, etc, and driving smart. It also helps that she's been paid for for years, so I can't justify a car payment. I was lucky in that when I bought mine, the previous owner kept her garaged for four years, putting only 15K miles on her. The Camaro is a great car, but like all cars, they require attention and routine maintenance to keep them on the road. I wish you luck with whatever you decide!
Old Mar 2, 2012 | 08:39 PM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
ZOMBIE THREAD!
My 92 has a nonworking odometer as well, so I took the cluster apart today. I replaced the capacitor because it had obviously failed and leaked, corroding some other leads too. The board seems pretty simple so replacing other parts wouldn't be too hard.
I'll repost later, when I test the fix out.
Old Mar 9, 2012 | 08:30 PM
freeyasoul03's Avatar
i have the same problem with my 92rs one night i had cruse control on and all of a sudden smoke was comming from under the dash i pull over and shut it down and didnt find out where it was comming from! when i started it back up the speed odometer ahd stopped working along with the trip does anyone have any suggestions
Old Mar 11, 2012 | 10:49 AM
weaksauce's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
No dice on the capacitor. Guess its off to the junkyard!
92camaroJoe
Jul 29, 2023 07:57 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
kyle5647
Aug 7, 2015 03:08 PM
