Gas gauge doesn't read correctly
Old Dec 17, 2009 | 08:41 PM
85IROCzzz's Avatar
Car: 91 Z28
Hey everybody so I bought an '85 IROC back in August and the gas gauge has never worked right. It always reads full but whenever my tank gets low and I go around a sharp turn or brake really fast, the needle moves all the way to the bottom then goes back up. This leads me to believe it's a bad sending unit but I want to make sure before I go and drop my entire rear end. Does anybody know if it's the sending unit or perhaps some other electrical issue?
Old Dec 23, 2009 | 10:32 PM
85IROCzzz's Avatar
Car: 91 Z28
Re: Gas gauge doesn't read correctly
Come on guys 30+ views and nobody knows?
Old Dec 23, 2009 | 10:36 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
it's a good question...mine has the opposite problem... it never says full, only about 3.4th full, and it will look almost empty with 1/2 a tank of gas left
Old Dec 23, 2009 | 11:06 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
From what I've seen on my many other vehicles, 99% of the time its the sending unit!!!
On my 98 Ranger, I was able to replace the electronic part (that works with the float) on the sending unit that was causing my problem. Lucky me, I didn't needed to replace the whole thing!(sending unit).
So, your problem, Pump=good, Electric Float=bad.
Old Dec 24, 2009 | 12:18 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
thats the exact same problem i have. i made multiple threads and no1 ever posts on them
Ghettobird52
Jul 5, 2024 11:18 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
