Best 12v Source To Add Accessories
Old Jan 9, 2010 | 05:14 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi everybody,
I'm gonna be adding a few aftermarket gauges to my car soon and I'm not to familiar with auto wiring. I did a little searching and didn't really find what I was looking for. What is the best (safest I guess) source to tap and where is the best place to tap it?
Alex
Old Jan 9, 2010 | 06:30 PM
Drew's Avatar
Re: Best 12v Source To Add Accessories
The front of the fuse block... There should be a couple empty spots labeled BAT for 12v constant and ACC for 12v switched.
Old Jan 9, 2010 | 11:52 PM
So I can just stick a spade terminal in there and an inline fuse on the wire? SWEET!
Thanks man!
Old Jan 11, 2010 | 12:04 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Figured i'd add to this instead of making another thread.
I already got 3 aftermarket gauges and a shift light running off of the fuse panel via spade terminals. However i've adding nitrous, controler and wideband. AND all 3 solenoids that require 12v keyed.
Where is the heaviest gauge wire that is a keyed 12v? What color is it?
Old Jan 11, 2010 | 04:33 PM
I've got another question sort of similar to the previous Q by 89rocz. I'd like to add an aftermarket clock to my center console (same location as the factory option clock) and it has a backlight that should only turn on with the lights, where would I hook it up to do that?
Alex
Old Jan 11, 2010 | 06:07 PM
Pocket's Avatar
Car: 91 Trans Am
Draw 12v from the brown dash wire. Confirm its lights 12v with a testlight or multimeter. Easy places to find it are the HVAC headunit and radio
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
