v6 to v8 swap, msd mod --Back to v8--
Old Jan 15, 2010 | 10:36 PM
55mikey55's Avatar
Car: 92 sonoma
Engine: 1985 LB9 tpi, stock
Transmission: NV3500
Axle/Gears: g80, 4.11 posi
can it be done and how do i do it?
Old Jan 15, 2010 | 11:30 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: v6 to v8 swap, msd mod --Back to v8--
Old Jan 17, 2010 | 04:34 AM
55mikey55's Avatar
Car: 92 sonoma
i know how to do it, but i don't know what to use as a jumper.
there's a red and blue wire, and the red is cut to use it with a v6. for the v8 to work, the (18-24gau) wire needs to be spliced back together, but there's not alot of room
Old Jan 17, 2010 | 10:57 AM
HCR13's Avatar
Car: 1987 Trans Am
ok, I'll help out, but I'm not exactly sure what you are referring to as "MSD mod"? If you have to reconnect a small cut wire, then get another small gauge wire (or appropriate gauge wire) and solder it into place. If you can't get to the wire ends, if there isn't enough, then open the box up to see inside where the ends go and you should be able to solder a new wire directly to the terminal it comes out of...
Old Jan 17, 2010 | 03:49 PM
55mikey55's Avatar
Car: 92 sonoma
yeah, the small wire is cut and the guy who originally put it in the truck cut it close to both sides so it wouldn't arc. now onto the next problem, how do i open it up? those are rivets right? that means i have to drill the holes.... reckon i could just go back with cap screws and nuts? eg. : screw|rubber|mounting surface|lock washer|nut
Old Jan 18, 2010 | 12:52 PM
HCR13's Avatar
Car: 1987 Trans Am
I've never had an MSD box...yet, so all this is just going by references and what I know about other electronics I've taken apart. But if its riveted, you should be able to put it back together with nuts and bolts or just put new pop-rivets in place...
Old Feb 11, 2010 | 11:24 PM
55mikey55's Avatar
Car: 92 sonoma
got my msd box fixed cost me $10 at a computer shop. he just soldered the wires back together. it was easy after i quit being a ***** and took the box apart...
Old Feb 11, 2010 | 11:48 PM
HCR13's Avatar
Car: 1987 Trans Am
yup, soldering is easy as pie...
beastin91rs
Oct 9, 2015 07:38 AM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
