New owner chiming in with steering column problems
Old Feb 10, 2010 | 07:04 AM
djdonte's Avatar
Just picked up an 86 z28 automatic with a 350 and 700r4. It ain't pretty but it runs good and was cheap. The body is a work in progress. It has the classic loose steering column that plagues GM cars from that year. The thing is when I turn the key, it will only crank if I jiggle the steering wheel kind of upwards. Anyone had this problem? Will fixing the loose column by removing the steering wheel fix this? It has also been suggested that I have a bad safety neutral switch, but I thought that is in the shifter. The car starts in park fine, haven't tried to start it in N. Thanks in advance!
Old Feb 10, 2010 | 08:54 AM
Pocket's Avatar
Car: 91 Trans Am
Re: New owner chiming in with steering column problems
Open up the column and tighten the lose bolts. If the problem is still present adjust the park lock at the base of the column near the IGN switch
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
