Drivers side power window...
Old Feb 10, 2010 | 10:51 PM
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Well I searched around and I think I probably have a switch problem but I am not sure. The drivers side power window just stopped working the other day. The strange thing about it was the fact that the passenger side was the slow window (tracks must be really dirty) and the drivers side seemed to function perfectly with no signs of drawing extra current. The pass side still functions however...
Any ideas? Not looking forward to taking the door apart and would like to avoid it.
Thanks!
Old Feb 11, 2010 | 10:03 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window Of Opportunity
Using a voltmeter or see if you get power on the left window switch pin A (brown wire) when you press the in the down mode.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 11, 2010 | 10:08 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Window Of Opportunity
Happy Racing!
UMMM in most States it's a law to drive with Lights ON even with a LIL rain... you must like tickets
Old Feb 11, 2010 | 10:37 AM
cleanwater7's Avatar
Car: 91, Z28
Engine: 5.7 TPI on ZZ4 long block
Axle/Gears: 3.73 posi
Re: Drivers side power window...
I went through this on the driver's side with the same thoughts. Check to see if you are getting power, of course, but if the motor has never been replaced or is older, for $18 replacement part from NAPA it worth the change out. Likely old age motor overloading. Getting the door panel off is the easy part, the rest has to be done slowly and carefully, but not complicated.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
