Long Start-up Time
Old Mar 3, 2010 | 08:06 PM
xaey's Avatar
Long Start-up Time
I'm very new to cars (just got started like 2 wks ago)
Anyways i got an 86 Camaro 5.0L and i noticed that when starting the car for the first time in the day or after a few hours of not using it, it will not start on the first try. It usually takes several tries before the engine starts running, and then afterwards i have to keep my foot lightly on the gas pedal to keep it warm else it'll just shut off. This takes about 5-10 minutes before I can start driving depending on how cold it is usually. Now I really don't know what kind of problem this is since i'm not really knowledgeable in cars. But I do know my battery is pretty new so I know its not that. Any suggestions?
Old Mar 3, 2010 | 08:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Long Start-up Time
Do you hear the fuel pump prime when you turn the key on?
Old Mar 3, 2010 | 08:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which 5L engine do you have? There are several.
Old Mar 3, 2010 | 09:20 PM
xaey's Avatar
Well I'm pretty sure its the fuel pump priming I hear except its not really a humming sound but more of a series of clicking, and kind of sounds like its coming from the front of the car. How would i check to make sure that's workin? As for the engine, sorry but all i know about it is that its a v8 5.0L 305cu. or something like that.
Old Mar 3, 2010 | 09:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Carbureted? TPI?
Old Mar 3, 2010 | 09:51 PM
xaey's Avatar
Carburetted
Old Mar 3, 2010 | 10:20 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Sounds like an electric choke issue.
I don't know your system specifically, but it sounds like the electric choke is not working.
Once it warms up it's OK, right?
Check the wire on the passenger side of the carb that plugs into the area @ the 'disc', the roung thing. Make sure it's plugged in, and if it is, check with a Volt Meter that is has power when you turn the key on ( don't know the exact specs, sorry )
Other guys here will give you many more specs than I have, but start there.
There are some guys here that know amazing things
Old Mar 3, 2010 | 10:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Before you check the choke circuit, is the choke plate even closing when you set the choke before you start it?
Old Mar 3, 2010 | 10:26 PM
Gregzz4's Avatar
Good point
He says he's new to cars and may need some direction as to how to check though
Old Mar 3, 2010 | 10:51 PM
xaey's Avatar
Hmm sounds interesting. Im going to have to check that in the morn. Not sure what any of that is, but im pretty good at researching at how to do specific things, but detailed instructions always save me time on my part. What should i expect, as i have a feeling it has to do with that. Also yes, once it's warmed up its good to go.
Old Mar 5, 2010 | 12:06 PM
xaey's Avatar
still no luck so far, but it would appear to me that the choke is probably the issue here. Any one got any ideas as to what I should check and in what order and where it's located? Thanks
Old Mar 5, 2010 | 08:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take off the air cleaner and look at the choke plate. It's the flap in the tower on top of the carb over the primaries. With the engine cold, open the throttle all the way once, and the choke plate should close.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
