92 RS cruise control
Old Mar 4, 2010 | 08:03 AM
3wheelnuts's Avatar
Car: 91 TRANS AM GTA WS6
Transmission: T5 5speed
Hi all, Anybody know where the cruise control module is installed on a 92 RS? I am trying to install one and by the harness, it looks like it may be on the passenger side somewhere. Thanks in advance.
Old Mar 4, 2010 | 08:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 92 RS cruise control
Pass side. The second pic in the following link will provide a general idea:
https://www.thirdgen.org/forums/engi...-function.html
JamesC
Old Mar 4, 2010 | 06:55 PM
3wheelnuts's Avatar
Thanks, your right, at least I know where to look.
Old Mar 4, 2010 | 08:02 PM
Pocket's Avatar
Car: 91 Trans Am
Literally behind the ECM mounted to a bracket bolted to the HVAC box
His pic shows the correct connector, but its deceiving on location. Its about 10" to the right of his hand
Old Mar 4, 2010 | 10:33 PM
3wheelnuts's Avatar
Thanks I't tear it apart and start installing tomorrow. I love the RS, just can't live without Cruise control. Already installed the power windows, locks and mirrors.
Old Mar 14, 2010 | 09:27 AM
3wheelnuts's Avatar
Anybody got a pic on the servo mounting location and the wiring passthrough location in the firewall?
Old Mar 14, 2010 | 09:37 AM
Pocket's Avatar
Car: 91 Trans Am
The engine bay mount changed from year to year, engine to engine. Generally its on the drivers side, on or in front of the washer tank. Its a large vacuum diaphragm with a cable coming out of it, you cant miss it
Firewall port is under the base of the steering column and runs the length of the frame rail in with the front light harness loom
Old Mar 14, 2010 | 09:51 AM
JamesC's Avatar
Here it is on my 85:
https://www.thirdgen.org/forums/atta...ctrics-gnd.jpg
JamesC
Old Mar 14, 2010 | 09:52 AM
3wheelnuts's Avatar
I am actualy installing this in a car without it. I was just trying to get it to look OE. There is a seperate harness for the cruise, I am looking for the spot to drill the hole for it.
Thank though.
Old Mar 14, 2010 | 09:54 AM
3wheelnuts's Avatar
Originally Posted by JamesC
I would never have thought to put it there.
Old Mar 14, 2010 | 02:01 PM
3wheelnuts's Avatar
OK, got it all installed, just one more detail. Where should I tie into the vaccum line for the servo? Can I just T in at the canister?
Old Mar 14, 2010 | 02:26 PM
3wheelnuts's Avatar
Looks like a good place to tie in?
Old Mar 14, 2010 | 04:05 PM
Pocket's Avatar
Car: 91 Trans Am
You mounted it in the stock location, there will be no problem with it there. Strange to see the vacuum line teed and capped for a non cruise car, but yes, you simply tee into it right there
Be sure the vacuum line goes to the SMALL port on the cruise head. The large port goes to the tube in the harness and attaches to a brake switch
Old Mar 14, 2010 | 04:13 PM
JamesC's Avatar
On my 85, the line from the vac tank (the upward pointing one in your pic), T's and one side goes to the servo.
JamesC
Old Mar 14, 2010 | 05:16 PM
3wheelnuts's Avatar
Got it. Test drive and everything is working well. Thanks Guys, couldn't have done it without your help.
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
