msd box help
Old Mar 6, 2010 | 01:33 PM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
msd box help
if the tach works in the car with the key turned ,think the box could still be fryd, or is there a seperate circut for the coil inside the box?, im alone so its hard to check without the key turned.
Old Mar 6, 2010 | 01:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: msd box help
What's the problem?
Old Mar 6, 2010 | 01:37 PM
84z .....'s Avatar
Re: msd box help
wont start now, im thinking when i boosted the car car today, i shorted it out
Old Mar 6, 2010 | 02:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: msd box help
What did you short, exactly?
Old Mar 6, 2010 | 02:34 PM
84z .....'s Avatar
Re: msd box help
my batt is in the back , so when i need to boost the car i go off of the termial under the hood i put on the inner fender but i touched the bolt that i installed the terminal with and its grounded right so im thinkin it just cost me a new street fire box
Old Mar 6, 2010 | 02:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: msd box help
Not likely unless you'd managed to create a short through the box itself.
Old Mar 6, 2010 | 02:54 PM
84z .....'s Avatar
Re: msd box help
just pulled off the #1 wire no spark, then coil wire and no f***** spark,
today mite be an expensive one, new box is 200+tax
Old Mar 6, 2010 | 02:56 PM
84z .....'s Avatar
Re: msd box help
the box is bolted to the cowl witch is why i think i fryd it. this time ill put a fuse in line before the + post
Old Mar 22, 2010 | 08:10 PM
thirdgen841986's Avatar
Car: 1984 recaro trans-am
Engine: zz4
Transmission: t-56
Axle/Gears: 3.73 9 bolt
Re: msd box help
I have a question for ya.. i have a msd 6al box in my 84 transam did you have any problem with the tach input?
$750 L98
Feb 1, 2025 02:25 PM
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
