fuel pump prime connector
Old Mar 9, 2010 | 04:18 PM
shatterme18's Avatar
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
where is the fuel pump prime connector on a 1985 camaro 2.8 liter v6 located
Old Mar 9, 2010 | 04:46 PM
uncapj's Avatar
Car: 1987 camaro rs limited
Engine: 2.8 ltr multiport fuel injected
Transmission: th700r
Axle/Gears: 3.43
Re: fuel pump prime connector
i dont think there is one i have an 87 2.8 i just put in a 1/4 of a tank of gas and turned the key on for 10 seconds and the car started but there is a fuel pressure tester nossle just in front of the distributor on the fuel rail to check if fuel is reaching the motor so turn the key a few times then depress the nozzle to let the air out then do it again until you get fuel i guess that would work
Old Mar 9, 2010 | 04:50 PM
Engine: 2.8 v6
right now the fuel pump aint coming on at all but before i drop tank i wanted to make sure it was the fuel pump
Old Mar 9, 2010 | 09:36 PM
Pocket's Avatar
Car: 91 Trans Am
Its a small red wire coming from the relay, generally 6" from it. If you cannot find it then unplug the relay and bridge the terminals with a short length of wire
Be sure your fuel pump/ECM fuse near the battery is not blown or this whole test will fail
Old Mar 12, 2010 | 02:12 AM
uncapj's Avatar
Axle/Gears: 3.43
run a peice of wire to the diagnostic conector from the battery and plug it into the hole on the bottom left corner of the diagnostic terminal it bypasses the circut and power is sent strate to the fuel pump thats how i lerned mine was bad so simply run battery voltage to terminal g on the assembly line diagnostic link or aldl diagnostic plug in
Old Mar 12, 2010 | 02:40 PM
Engine: 2.8 v6
k thanks i think pump bad
Old Mar 12, 2010 | 03:12 PM
Pocket's Avatar
Car: 91 Trans Am
Ouch
Hopefully youll drop the tank and not cut the hole
Old Mar 12, 2010 | 10:59 PM
Engine: 2.8 v6
yeah it sucks but i am going to drop tank
Old Mar 13, 2010 | 01:00 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello uncapj!!
Why don't you just ground the g terminal on the ALDL connector with a paperclip!! That's why the terminal is there, so that it can be done that way!!!
Old Mar 13, 2010 | 11:32 PM
uncapj's Avatar
Axle/Gears: 3.43
Which outlet on the giagnostic connector is it A because I know if you ground A and B together it sets of the codes on the cel, so A and G turns on the fuel pump.
sorry my spelling was so bad in the last posting i was half asleep it made me look like an idiot.
And what's wrong with cutting the hole. I did you can drop the axle if you want and have the time and the room. I didn't have the time or the room but I also fixed the hole the right way. I welded it shut not just put a bit of aluminum and cocking it to seal and riviting it to hold it to the body
your suposed to make a car fit you not make you fit the car just like modifying your motor its like saying you put a cat back exhaust its not original or you put an intake thats not factory or you ran nos or turbo/supercharged or complaining about running eibech springs or bilstien shocks or any other mod but i will keep the stock look down to the rims now
Old Mar 17, 2010 | 01:33 AM
Hello uncapj!!
Ground "A" to "G" on the ALDL, as for cutting the hole for the fuel pump replacement.........if that's what you want to do, go ahead, just be careful doing it!!!
I believe the best solution for the fuel pump, would be to install one in-line outside of the fuel tank!!!! Then you would never have to drop the tank, nor rip out your carpet!!
Old Mar 18, 2010 | 08:20 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You DON'T ground Terminal G on the ALDL... You put 12V to it! It's the constant-hot side of the relay switch! You GROUND the green wire at the relay to manually switch the relay if it's going to. If the relay switches, then the ECM is bad. I've had 2 bad ECMs, both with a code 54, and replacing the relay twice didn't help... It was when I replaced the ECM each time that the code 54 went away (the first one had a bad driver circuit and eventually failed altogether so bad that the engine wouldn't run).
Here's a diagram, and yes, I know it's slightly blurry... The relay is at the bottom.
:edit: And, when my fuel pump goes, I'm going to drop the tank AND cut the hole, using a door from a W-body. Rather than half-baking it, I plan on doing it right with the access hatch.
Old Mar 18, 2010 | 11:52 PM
Hello Maverick H1L!!
Putting a paperclip from the "A" "ground" "Black wire" ALDL terminal, to the "G" "Fuel Pump Relay" "Orange wire" ALDL terminal is grounding it, to complete the path!!
Sounds like potato/potatoe!!
Old Mar 19, 2010 | 03:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Umm... Hello! How is the fuel pump supposed to get any power without putting any power to it? Look at the wiring diagram I posted... Grounding the relay connector is going to do NOTHING, as that switch in the relay provides POWER to the fuel pump when the relay is switched by the ECM, not a ground!
And the relay coil, the part that magnetically switches the relay, is GROUNDED by the ECM complete the circuit. So, to properly test the fuel pump, relay, and wiring, you need to GROUND THE GREEN WIRE AT THE RELAY, with the ignition on, of course, and leave the ALDL alone.
Old Mar 20, 2010 | 01:36 AM
Hello Maverick H1L/uncapj!!
I see my error, I was trying to verify a "crapped" out fuel pump, so I placed a piece of wire from terminal "A" to terminal "G" on a recently purchased 1987 Camaro Z-28, and turned the key to "on", thinking that I would get the 12VDC that was required by completing the path, however, I didn't!! I naturally assumed that I didn't, because the fuel pump was in need of replacement, which it was, and has subsequently been replaced!!
I stand corrected, see, you learn something new every day!!
It took me a few minutes of looking at the wiring diagram that you had as an attachment, and after looking at the one in my service manual, and reviewing the procedures, yup, I was wrong!!
Sure did sound good though!!!
Thanks for "fixing" me!!
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
