power wire for computer?
Old Mar 12, 2010 | 06:51 PM
techno_1961's Avatar
so i have somthing draining my battery havent really figured it out yet itsa 86 iroc with a 305 tpi. i put some battery shutoffs on it hooked my radio memory right up to battery. should i hook the computer up to it too somehow ?
Old Mar 13, 2010 | 09:02 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: power wire for computer?
Honestly, I would find the problem instead of rigging the power. But, To answer your question, yes, you should keep constant power to the computer. It won't hurt anything if you don't though. It will just have to relearn everytime you drive the car.
Old Mar 15, 2010 | 08:26 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
More Power This Hour
Good advice from
1981LT1.
Sometimes the under-hood light does not go out so check that easy one first.
Then connect an ammeter in series with the battery.
(You can use a small bulb such as a side marker bulb if you don‘t have an ammeter.)
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
Round Out Your Life, Drive Oval Tracks
Old Mar 15, 2010 | 09:34 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
just posting so I can get updates, but by any chance do you have an amplifier hooked up? check that first if you have it hooked up to the 12v ign that supplies power to the radio... my battery drains completely after 3 days of non operation... not concerned about it ATM, but am gathering intel for when I tackle the problem...
Old Mar 15, 2010 | 09:36 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
BTW, aren't all F-Bodys already wired directly to the battery... If I remember correctly I have an orange wire I think that supplies power to the ECM, unplugged the car seems like it goes into limp mode... accelerate and you cause a backfire...
Old Mar 15, 2010 | 04:00 PM
1981LT1's Avatar
Engine: LT1; LT1
Yes, the computers are wired for constant battery power, but it is a very mimimal draw. Just enough to keep the memory charged. I would check the draw by placing a DVM between the battery and the negative cable and then start removing fuses one at a time until you find the culprit. If there is no results from this test, have your alternator checked. If the diodes stay open, it will let the current flow continuously and drain the battery.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Bryan F
Aug 18, 2015 02:28 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
