dome light problem
Old Mar 12, 2010 | 11:12 PM
shatterme18's Avatar
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
dome light problem
dome light stays on when doors are closed any solutions or answers
Old Mar 12, 2010 | 11:53 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: dome light problem
yup, you need to either check three things. Either one of your door switch triggers is grounding out somewhere, or your headlight switch is going bad. Try twisting the **** left and right over and over agian to see if your can jar out any foreign pieces of metal shavings that may of fallen and closed a circuit within the light switch. I can tell you the problem is there in either one of the 3. Should be an easy find bro.
Old Mar 13, 2010 | 12:53 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello shatterme18!!
Just asking, did you try turning the dome light off with the headlight switch?????
Sometimes the switch gets turned when you touch it, for whatever reason, and it becomes the too obvious, that's overlooked!!!
Old Mar 13, 2010 | 10:25 PM
Originally Posted by 87IROC-DAN61
Hello shatterme18!!
You just over looked my previous post.
I quoted "yup, you need to either check three things. Either one of your door switch triggers is grounding out somewhere, or your headlight switch is going bad. Try twisting the **** left and right over and over agian to see if your can jar out any foreign pieces of metal shavings that may of fallen and closed a circuit within the light switch. I can tell you the problem is there in either one of the 3. Should be an easy find bro.
Old Mar 13, 2010 | 10:27 PM
. Just kidding around with you 87IROC-DAN61.
Old Mar 15, 2010 | 01:38 AM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
did twisting the switch like everyone else said work? if not, try taking off the cover and wiggling the part that holds the bulb..i know its a bit different, but mine wont stay on, its a bad connection in the light holder for me. or, its kid of a long shot, but one of your door switches (the ones that get pushed in when you shut the door) could have somehow got broken. check those too. good luck.. oh you might also try unplugging your negative battery cable for a few mins and hooking it back up. those are the first things id check.
Old Mar 15, 2010 | 12:43 PM
Wiggling the part that holds the bulb does no good for the issue at hand. The circuit is closed, so how would wiggling it open the circuit? The problem lies in either the door switches, or the switch at the head light ****. Also disconnecting the battery does no good. The light is on because of a problem in the wiring, not volatile memory.
1992CamaroGirl
Dec 25, 2017 08:45 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
