Coil Wiring
Old Mar 24, 2010 | 05:42 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Coil Wiring
this is standard HEI (external coil) wiring, where does white (tach) cable goes ??
best regards
Old Mar 24, 2010 | 10:25 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tach This On The Race Schedule
The white wire goes to the coil primary, on the opposite end of the ignition switch line.
Happy Racing!
“Just One Of Them Racin’ Deals”
Old Mar 24, 2010 | 10:33 AM
WASyL's Avatar
Re: Tach This On The Race Schedule
as my english and f-body wiring are not strongest side a diagram or pictures would help with this kind of explenation, thru where this cable goes, left, right or middle side of firewall, where does this ignition swich is located ??
is it the white one on right?
Tach This On The Race Schedule - do you mean connect it to tachometer ?? will ECM see RPM's with this cabe disconnected ?
best regards
Old Mar 24, 2010 | 01:33 PM
NINÅ's Avatar
Transmission: 765R4
As you can see from the drawing you posted there is a white wire labeled tach.
Follow that wire to the firewall.
On the opposite of the firewall you should find it.
The ignition switch wire goes to the
12 V on your drawing.
Happy Racing!
Old Mar 24, 2010 | 01:59 PM
WASyL's Avatar
Dear Nina i know that and i would do that if my harness would be uncut but due to it is hacked i'm not able to do that and this is why i asked this question
best regards
Old Mar 24, 2010 | 06:30 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Coil Wiring
You've dug up the wrong spot. Its not in the steering column. That white wire is wiper control
It goes from the coil to the C100 (bulkhead near the booster) and into the dash harness. From there its a strait shot to the cluster
You need to be looking in the engine bay. Rear of the engine, near the dist on the coil. Should be two connectors with two wires each, gray body is the one you're after. One big pink wire and a small white wire. White is tach, pink is IGN
Old Mar 25, 2010 | 02:56 AM
WASyL's Avatar
Re: Coil Wiring
thanks a milion, my car is 88 but 87 diagram propably will be same, on C100 it's D6, right ??
best regards
Old Mar 25, 2010 | 06:11 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Coil Wiring
Yes, the pin is the same 82-92
Old Mar 25, 2010 | 06:14 AM
WASyL's Avatar
Re: Coil Wiring
thanks
best regards
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
