C100 Connector Info
Old Jan 5, 2020 | 01:02 PM
  #51
Dholland17's Avatar
Car: 1983 Z28 T-tops
Engine: 350 GM Crate
Re: C100 Connector Info
I got the blue comb out but how do I get the pins keeper out?
My directional now work but that pin is off and on so I want to replace it somehow because if I wiggle the wire near the bulkhead it goes out so it has a bad connection. It could be the cab side pin for all I know, maybe they just need a good cleaning.
Old Jan 5, 2020 | 01:08 PM
  #52
Dholland17's Avatar
This is the pin giving me trouble. I am trying to remove it on the engine side harness first tho. pin keeper??
Old Jan 5, 2020 | 01:58 PM
  #53
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
The bulk head (female fittings) use a precision screw driver or o-ring pick; insert in the end press and the fitting will come loose.
Harness fitting similar.
You will figure it out, they only go in one way. I am going from memory I repaired mine but it has been awhile.
Old Jan 5, 2020 | 02:14 PM
  #54
Dholland17's Avatar
the bulkhead male fitting, where do I insert my tiny screwdriver to release the pin? It is still a little gunky in and around the pin so it's not obvious to me at this point. From the inside or backside of the pin?
Old Jan 5, 2020 | 03:18 PM
  #55
Drew's Avatar
That's what she said... wait...
Old Jan 5, 2020 | 05:11 PM
  #56
FRMULA88's Avatar
Car: 1988 Formula
You are killing me..
Old Jan 5, 2020 | 05:13 PM
  #57
FRMULA88's Avatar
Car: 1988 Formula
[QUOTE=Drew;6347590]That's what she said... wait...
..it's all gunky and I cant see the hole... do I hit it from the front or the back....
Old Jan 5, 2020 | 06:08 PM
  #58
d00d you are just NOT RIGHT. I think you need to go get yourself a new sister.
Old Jan 2, 2021 | 07:58 PM
  #59
vorteciroc's Avatar
Top Answer: 1
To anyone that is looking for the photos that are missing from the beginning of this thread...
I have re-posted about 50% of the photos in a newer thread "C100 Revival " in the hyperlink below:
LINK
The OLD photos start with Post #20.
If there is enough interest/ demand... I will continue to dig-up more of the old photos.
They are stored (but completely un-catagorized in a mess of 10,000 random photos) in a now 15-year old Storage-Server, that I almost never turn on anymore.
Tuned Performance
Jul 3, 2019 05:24 PM
87350IROC
Jul 31, 2010 08:26 PM
t/adreams
Mar 8, 2010 09:16 PM
Superjustin13
Dec 19, 2009 05:25 AM
Nate86
Mar 30, 2005 07:21 PM
