fog light bulb change !!! 91 TA
Old Mar 31, 2010 | 09:35 PM
stan12777's Avatar
ok i bought the bulb H3, but how do i install it ? 91 TA !! i got responses before on a camaro but its not the same as the camaro to change, it seems i cant find any room to put my hand in there, is it easier from top of the car or the botom?
Old Apr 2, 2010 | 11:44 AM
Pocket's Avatar
Car: 91 Trans Am
Re: fog light bulb change !!! 91 TA
Fog bulbs are easiest from the front
2x T15 torx screws and the lens will come off. You may have to bend the nose cover out of the way slightly. The wires are just short enough to be difficult to reattach. Lucky for us, GM didnt use the best wiring/bulbs for our foglights and they burn out every 4-6 months with regular use so get used to swapping them
Old Apr 2, 2010 | 11:54 PM
stan12777's Avatar
i didnt see anywhere where the tox screws are for the fog lights, the signal lights have that but not sure about the fogs, i thought u can only install the bulb from the back housing !!!
Old Apr 3, 2010 | 07:57 AM
Pocket's Avatar
Car: 91 Trans Am
Take the two screws out of the turns. You should see the black retainers on the fogs. Screw is dead center of the black pieces. Like before, the nose needs to be pushed back slightly to see one screw
Old Apr 3, 2010 | 10:57 PM
stan12777's Avatar
great, thanks for the help guys.
jaridjohn
Jul 8, 2024 03:49 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
