no voltage at ignition module
Old Apr 4, 2010 | 04:16 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
car ran fine the other day, then i removed the manifold to check the valvetrain. i tightened the driver side valve cover back down on a pigtail and broke the wire. bought another pigtail and got no spark when i tried to crank the motor. checked the coil and it seemed to test bad so i got a new one. same result. ignition module tested bad, bought a new one, same result. theres no voltage output from the module, and with it being new, im stumped concerning whatever the problem is.
Old Apr 4, 2010 | 04:58 PM
bcmag's Avatar
Re: no voltage at ignition module
check all fuses may have popped when wires grounded out on pigtail.also make sure ground wires on back cyl. head are ok.
Old Apr 5, 2010 | 03:55 PM
Car: 1985 Trans Am
Engine: 360
All the fuses are good, and all the grounds are good. The ignition module i bought was bad so I bought another one that tested good. Having the same problem again.Another thing, I no longer have the HEI ignition. The module just has one plug coming from the ECM and the pigtail coming from the primary coil.And I forgot to mention that the other day I disconnected the ECM plug from the module and the car started, it just idled so low you couldnt even hear it running unless I gave it some gas, and even then it loped really bad. But it wouldn't start with the ECM plugged into the module.So after that I put in a spare ECM that I had, connected the ECM plug to the module and it cranked up. I'm wondering if something is wrong the the ECM that would cause it not to fire. Any ideas?
Old Apr 6, 2010 | 08:42 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ECM Condem
The part of the ECM which controls timing went bad.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Apr 6, 2010 | 09:49 AM
david_beast's Avatar
Car: 1985 Trans Am
Engine: 350 Small Block
Try changing the Ignition Condenser,Usually wires seems to pop out of it when it gets pretty old
Same thing happened to me too
Old Apr 8, 2010 | 12:01 PM
Car: 1985 Trans Am
Engine: 360
I went through all the hassle of replacing the ignition switch to get nowhere, although I probably did need to replace it because it had burned up the plug in it. I've pretty much narrowed it down to the ECM. And that's what I thought it was all along. The ECM has something to do with startup right? If that's the case then that has to be it, considering that it started up without the ECM plugged in but wouldn't start with it plugged in. I have one that will be at O'Reilly tomorrow morning.
If a new ECM doesn't change anything, I've lost all hope.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
