Timing problem
Old Apr 11, 2010 | 03:23 PM
Beast_Mode's Avatar
Timing problem
i was told that my timing wouldnt stay in time because the ignition module was either bad or broken. so i tested mine and its good. why else would my car not stay in time when set?
Old Apr 11, 2010 | 08:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Timing problem
what car? what motor? carbed, TPI, or TBI? computer controlled? are you checking timing with the EST still plugged up?
Old Apr 12, 2010 | 05:05 PM
Beast_Mode's Avatar
Re: Timing problem
89 Camaro RS v6 Multi fuel port
Old Apr 12, 2010 | 08:30 PM
Car: 1992 RS
Engine: Carbed 350
Re: Timing problem
The timing is going to be irratic and moving all around as long as the computer has control over it. You have to check and set BASE timing by unplugging the EST wire (Electronic Spark Timing) before you start the car, and check/adjust timing to spec with that unplugged, then after the BASE timing is set, you turn off car and plug the EST back up, then all should be as it should be (unles there's another problem like the EST module gone bad or something).
Old Apr 15, 2010 | 08:35 PM
Beast_Mode's Avatar
Re: Timing problem
thanx....im putting more effort in finding the problem rather then buying a whole new dizzy.
Old Apr 21, 2010 | 10:09 PM
Beast_Mode's Avatar
Re: Timing problem
The est wire, is the black and tan wire connected the ignition module right?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
