No headlights, gauge lights or tail lights?
Old Apr 16, 2010 | 09:33 PM
makiguy's Avatar
On my 91 camaro rs 3.1L my headlights, tail lights and dash lights do not turn on. I've replaced the switch, but now it appears that there is no power to the switch. We have power at the tail light fuse which also seems to function as a fuse for the headlights on the wiring diagram. So I'm assuming there is a power loss somewhere between fuse and switch. Does anyone have an suggestions on where to look?
As a side note the switch i purchased was for a model with daytime running lights (only model Autozone seems to carry) which my car does not have. It fits just fine and seems to have all the proper connections, does anyone know if this switch will still work properly?
Old Apr 22, 2010 | 07:12 AM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
Transmission: TH350, B&M shift kit, Huges 3000 sc
Axle/Gears: 3:23 Posi
Re: No headlights, gauge lights or tail lights?
I am having a simular prob, I just installed my stereo, the only thing I did different was hook up the grey illumination light to the stereo and now the headlight switch doesnt turn anything on and all the fuses are good??. I read in the Hanes manual that the headlight switch it self has a circuit breaker inside, when there is an over load it will not allow the headlight switch to work, Once you fix the problem the switch will automaticly function properly. Let me know how yours turned out, If this works I will post the fix here.
Old May 3, 2010 | 03:35 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
So did you then unhook that grey illumination wire?
Old May 3, 2010 | 04:32 PM
Pocket's Avatar
Car: 91 Trans Am
http://www.austinthirdgen.org/index.php?pid=19
Start looking there
You've got power to the fuseblock, but do you have anything at the light harness? IGN and light harness feeds are separate in the C100. You may have blown a fusible link
Old May 4, 2010 | 08:01 PM
makiguy's Avatar
Yea sorry, it was the fusible link underneath by the starter.
Old Aug 15, 2010 | 11:02 PM
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
hello i have a similar problem....started a new post "no headlights at all. help"
no high or low beams at all
no power going to connector
new bulb
multiswitch will not switch (click from high to low)
car starts ok...fusible link on starter...how do you check.....never had to replace one before.
Old Aug 16, 2010 | 12:44 AM
makiguy's Avatar
mh82camaro it turns out mine was the fusable link. To check it out just jack the front end of the car up and there will be two wires coming off the starter i think, maybe three. The fusable link will just be a piece of wire thats a few guages smaller than the rest.(Don't remember what guages they were.) But the bad one will have a soft spot in it which is where the fusable link blew. I just went to Autozone bought a new fusable link and spliced it in. It's not too difficult. Mine was a 91 camaro rs though so yours could possibly be a little different
Old Aug 21, 2010 | 09:47 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Weird i have this same issue, ill have to look at my starter i suppose. I can get blinkers, thats about it, otherwise sidemarkers and everything else is a no go.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
Fronzizzle
Aug 19, 2015 01:36 PM
tnrednneck
Aug 13, 2015 08:57 AM
