how to wire in stock gauges 91 Formula
Old May 15, 2010 | 12:30 AM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
ok i have a stock gauge set in the car id like to use went carb looking for wiring solutions for the following I HAVE NO TPI Wiring that came with the car I have to start from scratch
speedo with T-5
gas level
oil pressure
temp gauge
dual fans
RPM gauges
volt gauge
thanks
Old May 16, 2010 | 03:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how to wire in stock gauges 91 Formula
so you have no dash harness?
Old May 16, 2010 | 07:12 PM
mackjar66's Avatar
Car: 1989 GTA
no i have the dash harness all intact just not sure where to start or even if i can still use the stock gauges
Old May 16, 2010 | 07:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the gauges will work without the computer, the fans may not.
speedo may not work, i know ecm gets the speed signal, but in not sure if the gauge will be affected
Old May 16, 2010 | 08:23 PM
mackjar66's Avatar
Car: 1989 GTA
ok so just wire in the hot and grounds to the connectors at the firewall or directly to the dash harness
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
