digital dash swap questions
Old May 22, 2010 | 08:42 AM
diablood5's Avatar
Car: 1986 trans am
Engine: goodwrench 350, 4 bolt main.
i have a trans am with a digital dash that i want to swap into my 86 firebird. what parts do i need to take off the donor car to make it work in mine. do i need the wire harness only ?is there a brain box or computer that i will also need ? any thing to make the speedometer and tach work?heat controls?
Old May 22, 2010 | 09:22 AM
diablood5's Avatar
Car: 1986 trans am
Re: digital dash swap questions
Old May 22, 2010 | 11:08 AM
diablood5's Avatar
Car: 1986 trans am
can any one help me???
Old May 22, 2010 | 11:11 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
good question. however prolly going to need alot of **** from the donor car. id just keep it stock. but its up to you. hopefully somebody on here knows the answer. GL
Old May 22, 2010 | 04:29 PM
diablood5's Avatar
Car: 1986 trans am
has anyone ever done this before?
Old May 22, 2010 | 07:37 PM
diablood5's Avatar
Car: 1986 trans am
Old May 23, 2010 | 12:33 PM
diablood5's Avatar
Car: 1986 trans am
someone has to have done this before...
Old May 23, 2010 | 01:01 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
My understanding is that to go from analog to digital you would need to swap out the entire wiring harness from the digital car into whatever you are putting it in. And if you are going from digital to analog the harness just needs to be modified because all of the connections are there along with extras..
Old May 26, 2010 | 12:43 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
I installed a 88 GTA digital dash into my 85 Z28. I took EVERYTHING, from the bulkhead connector to the heater controls. If the wires came from the dash I took them till the met a connector or ended. The heater controls are the same but its easier to have more than you need than to try to guess later. To this day I have been unable to find a good sorce for a wiring diagram , thats why its easier to take it all and install it all into your car. You will see where alot of the wire colors match up to your old wires(GM is good about keeping certain wires the same colors). Just to prove that GM keeps wiring the same I also installed the original dash from my Z28 into my 69 Chevelle(fits very nicely) and spliced the wires to the original wires and almost all were the same colors. Good luck and hope this helps some
Old May 26, 2010 | 03:43 PM
diablood5's Avatar
Car: 1986 trans am
thanks .. yes it does help.. alot. how hard was it to change out the harness. how long did it take you to do..can the swap be done in a weekend or will it take a good bit or time?
Old May 27, 2010 | 05:58 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Yes it can be done in a weekend! I actually installed the entire interior from the GTA in that amount of time. If you un hook the bulkhead connector and take everything with the dash you should be able to put it into your car and hook your underhood connectors back onto the bulkhead connector along with the rest. Are you using the same style motor/trans as the donor car? That might make a small difference. It will also depend if both cars have the same options(power window/ lock/ ect. You can leave off any of these you dont need or add from your car what you do, everythinf plugs into something or goes somewhere. Its easier to write on some masking tape and put them by the connector what the wires go to when you unplug them so its easier to remember when you plug them back together. Its not as hard as you think, just take your time and dont cut any wires, find the connectores. Good luck
Old May 29, 2010 | 01:27 AM
cj92firebird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
Sorry to hijack the thread, but I was wondering if they put digital dash's in a V6 firebird. If not would one out of a V8 firebird work?
Old May 31, 2010 | 09:09 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
A far as I know the digital dash was an option , but am un sure if it was only available on V8 birds. I do know that the camaro berlinettas with a V6 could have a digital dash. wouldnt want to tell you wrong but for sure the tach from a V8 wouldnt work on the V6, but all the sensors if plugged in should work. Would like to compare a electrical print from a digital dash to a standard dash before saying yes for sure. ANYTHING can be MADE to work with enough time and patience and proper wiring diagrams!
Old Jun 3, 2010 | 12:18 AM
JT's Avatar
JT
Community Administrator
I think the answer to this question is up in the air. I recently did some research on the digital dash myself. I found that GM assigned a part number for the digital dash on a V6 (2.8) Firebird in 1986. It appears the only year where there is specifically a GM part number assigned for the digital dash (U52) and the V6. I don't know if that means it exists.
Old Oct 3, 2010 | 03:35 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I realize this is a dad thread but if anyone is looking I have a complete 88 GTA digital dash. Comes with everything and none of the wires were cut.
Old Oct 31, 2010 | 01:44 AM
themanricky1117's Avatar
Car: 1989 Pontiac Firebird Base T Top
Engine: 305 V8 carb
would that dash work in an 89 firebird??
Old Oct 31, 2010 | 02:07 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
You need to list a price, otherwise the Mods will bite one ear off at a time..
Old Oct 31, 2010 | 12:32 PM
theNMBR27's Avatar
Yes, it will fit any year firebird. I'm lookin to get $350 or best. Pm for pictures and more details.
Old Oct 31, 2010 | 01:14 PM
Drew's Avatar
Generally any buying/selling needs to be done in the classifieds.
Old Oct 31, 2010 | 01:54 PM
theNMBR27's Avatar
Thanks for clearing that up. Hence the pm..
Old Nov 3, 2011 | 11:19 PM
blackfrontier's Avatar
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
I am not fond of the digital dash in my 89 GTA and someday will ditch is for analog so it can look like a normal car lol!
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
