My blower motor works intermittently...
Transmission: World Class T-5
Axle/Gears: BW 3.45
First let me state that I'm kind of a dummy with electronic, so go easy on me.
My blower motor goes on and off intermittently, so I'm thinking I've got a loose connection somewhere. It might be working just fine, (all speeds), and then I hit a bump or something and it stops blowing. I was convinced,(psuedo-long story), that the connector that plugs into the motor itself was bad so I cut it off and spliced a new connection. I've replaced the blower motor itself, I've checked the relays and they look good, (not burned up), so what's loose?
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: My blower motor works intermittently...
there should be a ground wire near the heater hoses at the firewall and one from the engine to the firewall.
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
where did you guys find replacements? im looking to get grab a new non a/c one but im having trouble, any p/n's?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i just went through a hassle with blower motor . i understand your frustration . power runs from fuse panel to htr./AC control panel . its a brown wire with gray disconnect directly behind control panel . the disconnect had become corroded and no longer let current pass to control panel switch . could be your problem also . good luck .
Axle/Gears: BW 3.45
Thanks, I'll give that a try.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Street Lethal
Aug 13, 2015 08:28 PM
