Blinkers on in the dash all the time
Old Jun 14, 2010 | 04:01 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
so yea my blinkers work just fine, and so do the rest of my lights and dash lights, but when i turn on my headlights my blinker light comes on in my dash like this i still have to click it to make it click and it still works just fine buyt it never goes off in the dash? anyone know what what the problem could be? its just annoying as hell. to have it on at night time when im not useing it, i want it to just blibk when im useing it darnit lol.
Old Jun 14, 2010 | 11:25 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blinkers On The Blink
Have you replaced any light bulbs lately?
Also, check for open grounds caused by loose connections in the connectors going to the dash, and cracked circuit board traces.
Happy Racing!
“I Didn’t Jump The Start, The Flagman Was Late”
Old Jun 14, 2010 | 11:37 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Blinkers On The Blink
yup^ that will do it
Old Jun 14, 2010 | 04:07 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: Blinkers on in the dash all the time
ill try and hange the bulb, but were would the ground be?
i dont even know how i got the DASH lights to come on, i found 3 different wires behind my stero twisted 2them and idk they just came on.
butr were would the ground be for the blinkers?
Old Jun 15, 2010 | 11:30 AM
NINÅ's Avatar
Transmission: 765R4
Grounds, But No Coffee
The grounds are located on the convenience center bracket.
The convenience center is located behind the knee bolster.
The convenience center contains the flasher
(just to help you identify it).
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Jun 15, 2010 | 04:11 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
i dont mean to sound dumb.... but ... what?
Old Jun 17, 2010 | 04:09 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
does the convenience center bracket hold the stero and stuff?
Old Jun 18, 2010 | 05:01 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Its under the dash, mounted on the side opposite of the fuse panel. It has relays and other electrical things plugged into it.
Old Jun 20, 2010 | 03:27 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
i found a few blinkler realated things... but not the ground anychance someone could PLEASE take a pic of the ground and with that pic explain were its located for a 91 bird
Old Jun 20, 2010 | 05:11 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
There are two grounds for the front lights that ground to the chassis, one on each side. I know for a fact that when one of mine was not grunded, I got a constant blinker on. They mound somewhere behind the headlight buckets I am guess, I relocated mine slightly when I ran the wiring differently
Old Jun 20, 2010 | 09:30 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
can i please get a pic bud lol
Old Jun 21, 2010 | 08:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
They're not hard to find, seeing as how they are generally right under the headlight assembly's bracket that bolts to the front of the radiator support, but on the back (battery and air filter side) of the support. Each side will have a ring terminal with 2 black wires in it, attached to the body by a 7mm screw. Sorry, I can't get you a pic, as my car is completely wireless except for the spark plug wires and negative battery cable. Since it's the one on the right side that is on in the dash, you'll want to check out the passenger's side first. Also, give a tug on the headlight plug and also the park lamp/turn signal plug to see if the wires come out. When a ground is lost, the power will use any means necessary to find ground if it can.
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
