Electric or manual?????
Old Jun 14, 2010 | 11:48 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Which is better?
The only thing working is the tach--that's it!!
So, what gauges are more reliable....
Electric or Manual,
and why do you use them?
I ask because we will be getting gauges soon!!
Thanks for the help!!
Old Jun 15, 2010 | 07:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Electric or manual?????
Elec are easier to install because you only have to run wires.
Mech gauges need a bigger hole in firewall to get sender unit through ( especially coolant temp gauge ) because it is permanantly attached to gauge
If you blow a oil line on a elec gauge you won't fill your dash with oil.
Pac J
May 17, 2020 10:44 AM
bjpotter
Oct 2, 2015 09:12 AM
tattmann
Sep 27, 2015 05:20 PM
lanceflame44
Sep 25, 2015 12:28 PM
Magman
Sep 12, 2015 11:55 PM
