Blower Motor-Low and Medium only
Old Jun 25, 2010 | 05:13 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
I have replaced the switch behind the ac/heat control panel and still no high. Any suggestions?
I know there is a resistor in the blower motor harness under the hood, does any one know the value? Thanks in advance!
Old Jun 25, 2010 | 06:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Blower Motor-Low and Medium only
I think I read that the resistor handles the lower speeds only, so that wouldn't be the issue. Have you tried swapping out the relay? It's under the hood as well.
Old Jun 25, 2010 | 06:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Relay.
JamesC
Old Jun 25, 2010 | 06:53 PM
texascat2's Avatar
That will be my next move. I know the resistor handles low and medium but the service manual says check the resistor. I'll check the relay!
Both of you! I'll let you two know! This website totally ROCKS!
Old Jun 28, 2010 | 11:19 AM
texascat2's Avatar
Is it necessary to pull the neg. battery cable to replace the relay?
Old Jun 28, 2010 | 11:35 AM
JamesC's Avatar
Whenever I'm messing around with electronics, I yank it as a matter of policy.
JamesC
Old Jun 28, 2010 | 11:46 AM
texascat2's Avatar
Thank you sir! Will do.
Old Jun 28, 2010 | 12:02 PM
texascat2's Avatar
JamesC
Is there a way to check the relay? I've read different view points about this.
Old Jun 28, 2010 | 12:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Swap N’ Shop
The fastest way to check the relay is to swap it with a new one.
However if you’re on a budget, apply 12 volts
(throw a 1 amp fuse in line for safety) to pin D orange wire.
Does the relay click?
You can keep the car off while you’re testing.
(Wire colors are subject to change year to year.)
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Jun 28, 2010 | 03:31 PM
texascat2's Avatar
Re: Swap N’ Shop
Well, it's not the relay either. Next?
Old Jun 28, 2010 | 04:13 PM
JamesC's Avatar
https://www.thirdgen.org/forums/elec...aro-rs-no.html
JamesC
Old Jun 28, 2010 | 04:37 PM
texascat2's Avatar
Thank you James! I cut and pasted all the tests and pictures for the "idiot" plug. Will let you know what I find.
Old Jun 28, 2010 | 06:43 PM
texascat2's Avatar
OK, my grey connector is not melted but the black connector looks like this. I copied this from another post. My grey connector (where this shows two red wires connected looks good). Should the burnt black connector look this way?
Old Jun 28, 2010 | 07:00 PM
texascat2's Avatar
Ahaa! After further inspection the inside of the grey connector is BURNT. Will post the results in a few!
Old Jun 28, 2010 | 09:03 PM
Drew's Avatar
Wire nut... It's probably not related to your problem, but I'd eliminate that wire nut. A length of heat shrink tubing, some solder, and an iron would clean that up in a hurry.
Old Jun 28, 2010 | 09:06 PM
texascat2's Avatar
Ok, took longer to update my cell phone software than to fix the bad connector! Thank you James for your knowledge and your built in search engine! That was the exact fix! I'm posting a couple of pics from my cell phone. Be sure you take your grey connector apart to check for damage! This website ROCKS! I'm having trouble posting my pics. I'll try again later.
Old Jun 28, 2010 | 09:07 PM
texascat2's Avatar
The wire nut was from a post in 2007.
Old Jun 28, 2010 | 10:22 PM
texascat2's Avatar
Ok, see if I can post a couple of pictures of the culprit connector![ATTACH]Blower Motor-Low and Medium only-bad-grey-connector.jpg
Blower Motor-Low and Medium only-bad-grey-connector-2.jpg[/ATTACH]
Here are two pictures of the BAD GREY connector! If you have a blower motor that will NOT come on on high, check this grey connector, it is more than likely fried!
Once again, THANKS TO JamesC guru of Third Gen.
Old Aug 19, 2010 | 06:48 PM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
James, you seem to know your stuff, my 1991 RS has a burn smell and a little smoke from heater / a/c selector switches and even when top on is in off position, fan will still blow, and it blows out defrost vents, when on vent position, please help, can you replace the whole switch assembly, what is the cure ol' wise one!!!
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Dec 2, 2015 03:53 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
buckeyecelt
Sep 24, 2015 05:50 AM
