Alarm keeps beeping until battery is dead 86 Fbird
Old Jul 6, 2010 | 10:41 AM
Telerooster's Avatar
Is there anyway to bypass this. I'm trying to get my sons car running but the alarm system keeps draining the battery.
Old Jul 6, 2010 | 12:16 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Squawking Bird
With no information on which type of alarm it is we can’t tell you what to do to the alarm electronics itself.
However to keep from killing the battery disconnect the power wire going to the alarm.
Now you will be able to get the car running.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Jul 9, 2010 | 07:53 AM
Re: Squawking Bird
Honestly I don't even know where the alarm is - just keeps going off and flashing lights every time the door gets opened. All I can see is a light on the dash. The battery reads good, but hit the key and nothing - my fear is the alarm is somehow interupting the starter circuit.
Old Jul 12, 2010 | 08:57 AM
NINÅ's Avatar
Transmission: 765R4
Squawking Bird
The alarm is probably behind the knee bolster.
After removing the bolster you’ll probable see a box with dimensions ~= 3” x 4” x 5”.
If you cut the power input that should disable the alarm.
You can do that, then report your findings.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jul 21, 2010 | 07:46 AM
Re: Squawking Bird
Thanks so much! I found the alarm box and pulled connectors until the lights stopped flashing. I was then able to actually start the car. Now I have the next problem which is a leaky brake line that needs to be fixed so I can wax this thing and put a for sale sign in the window. Thanks again for your help!
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
92projectcamaro
Sep 29, 2015 07:07 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
