Column and front turn signal wiring
Old Jul 17, 2010 | 03:49 PM
Zipacna's Avatar
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
I have an '88 Camaro. When I got it, it looked like it had been stripped in order to repaint the entire car so I had no dash, wiring, anything.
I chose to take this car and keep it lightweight while still being functional because it does need to be retitled as assembled.
I have all the wiring I need for the gauges, dash, blower, tail lights, you name it.
But I can't find anywhere a pin out of the turn signal switch wiring harness and the rest of the column wiring. The left, right, high beam, and wiper controls is all I really need, but if someone had it all, that would be amazing. I'm posting on here to save my self having to contort myself in order to get a volt meter in there haha.
The other question I have is the front amber lights and the marker lights. The amber lights have a blue, brown and ground. And the marker lights only have blue and brown so I'm not sure how those are supposed to go.
tl;dr I did a search, couldn't find a wiring diagram for the column, so if anyone has it, I will be eternal grateful.
Old Jul 18, 2010 | 12:24 PM
Zipacna's Avatar
Engine: 350ci TPI
Re: Column and front turn signal wiring
Scratch that, I actually found most of it on autozone's wiring diagrams, it wasn't in my chilton though? maybe i'm missing a page.
Old Sep 8, 2010 | 10:18 PM
D112192's Avatar
Car: 82 Camaro Z28 Pace Car
Engine: 305 H
Transmission: Saginaw 4 speed
Anyone.... I having the same issue. I need the wire color coded for 1982 z28 Camaro pace car 305 4bb Washer Switch, With Tilt Column & Delay Wipers. Does anyone has info? Also I replaced my steering column with 1987 Iroc z28, but the washer switch has different color scheme. please assist.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 13, 2015 12:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
Fronzizzle
Aug 9, 2015 01:15 PM
