Replacing the tachometer internals with better aftermarket ?
Old Jul 18, 2010 | 09:38 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Hi guys,
I've had this idea for a while after reading everywhere that our tachometer were basically junk, and that mine was working erratically : has anyone tried replacing the internals of a factory tachometer with those of a good, precise aftermarket one ?
I want my car to look stock but with slight improvements over the cheap original systems.
Thanks !
Old Jul 19, 2010 | 01:14 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
French Fried Tach
You should be able to accomplish it.
If you don’t get specific replies you can use most tachometer drivers.
After the swap you’ll probably have to adjust a trimpot.
The trimpot will be next to the first amplifier transistor in the replacement driver.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
TheExaminer
Aug 25, 2015 07:34 PM
theurge
Aug 21, 2015 12:46 PM
ChevyZ71
Aug 13, 2015 07:30 AM
92purpz28
Aug 11, 2015 02:30 PM
