My Lights have a mind of their own
Old Jul 21, 2010 | 11:23 AM
vindennl48's Avatar
Car: 1987 GTA Trans Am
Engine: Carb. 305, bored .030
Axle/Gears: 3.73 posi
Hey guys, first off I'm new to the forums so hello!
I have an 87 GTA Trans am with a mind of its own. Sometimes when I turned my headlights on, both blinkers would turn on as well but wouldn't blink. Just stay on, as well as the high beams and i could not shut them off unless i turned off the headlights switch. After a few minutes they would go back to normal and everything will function correctly. It doesn't happen every time but quite frequently.
Well, now the high beam dash indicator is always on, regardless if my high beams are activated or not and my left headlight is now extremely dim. I know its not the light because I just replaced them, tried switching the headlights with each other and they both work. So I'm wondering if its just a bad connection, a relay? Should I just rip the entire wiring system out and replace it?
Thanks!
Old Jul 22, 2010 | 01:39 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Just Tell Your Lights To Never Mind
Yes based on your description it’s been messed with by the PO.
It might be faster to remove and replace than troubleshoot if it’s a mess.
Also, check the grounds.
They might look good but have high resistance.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
GTAman
Mar 15, 2019 11:40 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
