Broken Cruise Control
Old Jul 22, 2010 | 12:20 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
The title I think speaks for itself. Why is it my cruise control isnt working? I recently replaced alot of the fuses which fixed most of the electrical but cruise is still broken.
Old Jul 22, 2010 | 12:40 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Broken Cruise Control
Mine doesn't work either. I think it's the switch on top of the clutch or brake pedal misaligned, just need to get under there and fix and/or replace it. Might be worth a look for you to check that out too.
Old Sep 14, 2010 | 09:44 AM
TSL's Avatar
TSL
Car: 1992 Chevy Camaro Z28 G92
I am having the same problem. Just replace the push rod bushing on my clutch thinking that would fix the problem. When my old bushing broke off, The cruise stopped working. It was zip tied for about 2 months. I figured the clutch was resting on the senser. New bushing went on and nothing happened... Senser possibly stuck? Let me know if you discovered anything
Old Sep 14, 2010 | 10:36 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If it helps anyone, here's the wiring diag for cruise: http://www.austinthirdgen.org/mkport...se_control.jpg
Wiring diags for almost everything are here: http://www.austinthirdgen.org/index.php?pid=19
Old Sep 17, 2010 | 05:56 PM
RussC's Avatar
i just fixed mine the other day, turns out it was the swich in the signel light lever. i replaced the lever and now it works perfect.
Old Sep 17, 2010 | 06:02 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
The two most common causes are the brake light switch on the arm of the brake pedal and the cruise control module behind the passenger side dash.
Old Mar 5, 2011 | 06:56 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
87 IROC Cruise Control Module
I have been looking for my cruise control module.. You state that it is on the passenger side. Take off protector panel. It is located up by the ecm? I still don't see it.
Old Mar 5, 2011 | 08:19 PM
red rock's Avatar
Car: 1987 iroc
Re: 87 IROC Cruise Control Module
Its about 4" square 3/4" thick mounted on the end of the heater box on passenger side. It's a tight fit to get to, but you should'nt have to remove any dash parts.
Old Mar 7, 2011 | 07:39 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Thank you. Found it.. Kinda tricky to get out.. 3 screws and a little wiggling.. But she came out..
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
