hazards work blinkers don't!
Old Aug 8, 2010 | 09:25 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
all the parking lights will come on. push the hazard switch and all the proper lights flash. flip the turn signals on right or left and the light on the dash comes on and stays lit like i have a blown bulb which obviously isn't the case. i checked fuses and none are blown either. the 2 silver fuses i switched and still the same thing. i don't know what the problem could be. any advise on what to check next???
Old Aug 8, 2010 | 10:01 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: hazards work blinkers don't!
have you made sure all the bulbs are seated right? They go in a certain way and sometimes they'll light up (but not the second filament inside)...
Old Aug 9, 2010 | 05:45 AM
i haven't double checked the bulbs yet but my blinkers worked on the way to work then i got off work went to make the first turn and then they didn't. but like i said the hazards still flash which is all the turn signal bulbs. just when i hit the turn signals from the lever the dash light stays lit not blinking and the outside lights stays on. front and back. how can all the hazards work properly and then the turn signals not work when activated seperately?
Old Aug 9, 2010 | 05:51 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
the T/S flasher is bad, the T/S and H use a different flasher, 1 for each.
Old Aug 9, 2010 | 06:42 AM
are they the silver ones? i will check them again. cause that was the second thing i did. first was checking blinking patterns. i did check all fuses. when i got to the flashers i pulled them and i thought i switched them but might have put them into same slot. will do that before i go to work. anything else as a just in case?
Old Aug 9, 2010 | 06:50 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just swap them around for a test, GM has done that for years, flashers for each one.
turn on hazzards to tell which one is clicking/working.
Old Aug 9, 2010 | 07:11 AM
i checked the 2 silver ones in the fuse panel. switched them and pulled them. nothing changed. hazards work with them out. did see a hazard fuse. it is good. then there is a turn b/u fuse it is good. maybe then the two silvers are bad? all regular fuses good though checked them all. no way to check the silvers... right? other than what i did?
Old Aug 9, 2010 | 08:25 AM
i listened and can hear clicking with hazards no clicking with turns. silvers i was looking at were in fuse panel. are the flasher up by the column then. never heard of flashers being hidden before. and it started raining to go with it. ugh!
Old Aug 9, 2010 | 08:35 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no they often hide them, took years to find the one in my wagon, it was tuck a mile deep into the dash.
find the one that clicks and you found em.
Old Aug 9, 2010 | 08:48 AM
alright! i found one not clicking and the other that is is the hazards. tucked behind a little black box. still don't know where the hazard one is but the one that i found i pulled it and the dash indicators went out. and the bulbs on the outside don't come on. hazards still work on dash and outside of car. i got the bugger. i gotta leave for work early and stop buy the parts shop and pick one up. thanks gumby this thing was driving me crazy i hate not using turn signals. when i get home i'll let you know if this fixes it.
Old Aug 9, 2010 | 09:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just member hand singls are still legal if you get a cop behind you.
straight out for left, arm up for right.
Old Aug 10, 2010 | 07:05 AM
i got the flasher in and the blinkers work again. lol funny you should say that about the hand signals i was thinkin that and i actually did that on the way to work and people thought i was waving at them! the ignorance. nice to have them fixed. now people can see the sequentials again. just have to find the hazard one in the near future and replace it just in case... thanks again.
Old Aug 10, 2010 | 09:34 AM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
im so lost... i also have this problem.. my hazards work but when i put the left blinker on it wont work and all bulbs are good...
do you have a pic of what this part looks like?
Old Aug 11, 2010 | 11:08 AM
a flasher is about 1" around 1" tall silver with 2 prong connector. hard to find but you will know when you see it. or go one parts store website for pic. i used flasher 552. makes my sequential signals a little slower.
Old May 31, 2011 | 08:58 AM
foxmartin1's Avatar
Car: 1989 firebird formula
Engine: 5.0L V8
Do you have a picture of where its located? I have the same problem and would like to know before I tear down the dash
Old May 31, 2011 | 09:01 AM
foxmartin1's Avatar
Engine: 5.0L V8
also my dash indicators don't work
Old May 31, 2011 | 09:08 AM
don't have a pic, but there is a black box right there near the diagnostic port. the turn signal flasher should be tucked up there. happy hunting.
1992rs/ss
Jan 31, 2025 05:10 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
