Headlights will not come up..I've tried everything
Old Aug 11, 2010 | 12:06 PM
02SLPTransAm's Avatar
Car: 1991 Firebird & 2002 Trans Am WS.6
Engine: 305 TBI & 5.7 350 LS1
Transmission: A4 & M6
Car: 1991 Firebird 305TBI
I searched and read just about every headlight problem thread on this forum and tried everything. My headlights worked fine until I wrecked the car last year. I have a 1992 V6 Firebird donor parts car that I have been piecing my car back together with. The headlights work fine on it, so I swapped out the headlight module and that did nothing. I then swapped out the headlight switch and still no cure. I have a circuit tester and I am not getting any power to the plug that you plug the motor into. The V6 car has power and I even put the module off my car and the switch off my car and they worked fine on it.
Tell me there is something that I am forgetting. Is there a relay or fuse that I am overlooking.
Old Aug 11, 2010 | 12:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Missing Link I Think
Using your tester, find out if you have power on the red wire going to the headlight switch.
If you don’t, check the fusible link near the battery.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Aug 11, 2010 | 03:38 PM
Re: Missing Link I Think
Thank you for the advice. I just tried that and I have power there. I just do not have any power to the end of the plugs. I know the motors are good because I tried them on the other car I have. Just frustrated because I know there is something that I am missing. The headlights worked fine before the wreck.
Old Aug 12, 2010 | 01:07 PM
NINÅ's Avatar
Transmission: 765R4
Put the light switch to the ON position.
Make sure you have power on the
yellow wire, brown wire, and orange wires going to the module.
Make sure the
black wire is grounded.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Aug 12, 2010 | 05:50 PM
yellow, orange, brown, black, orange is how the bigger plug on the module goes. I have power to the yellow and brown only. Going to look into this a little further. This has to be the problem. Is there a fusible link somewhere on the orange wires?
Thanks a ton for your help!!
Old Aug 12, 2010 | 06:07 PM
I did the same test on my 1992 donor car and I had power to the yellow and both orange wires. No power to brown. The headlights work just fine on the car. I'm confused to why the brown has no power in the car that is working and power in the car that isn't.
Old Aug 16, 2010 | 08:55 AM
NINÅ's Avatar
Transmission: 765R4
The orange wires get their power from two 15 amp circuit breakers or fusible link(s) depending on year.
First look in the fuse block if they’re there they are labeled
HDLP DR1 and HDLP DR2.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Aug 16, 2010 | 09:40 AM
I am not sure, I will take a look after work tomorrow. Thanks again for your help!
Old Aug 25, 2010 | 12:43 PM
Still no luck...I look at the wiring diagram and it looks like the two orange wires going to the module have 15 amp fuses or fusible links as you mentioned. Where are these?? I have no power to those wires..that has to be the issue.
Old Aug 25, 2010 | 01:46 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I jus finished wrestling with my headlights.. although on an 86. Your fusible links are actually very likely your problem. Force from your accident might have jarred something causing them to blow. If your not getting power at one of your headlight motors, this is usually why.
Old Aug 25, 2010 | 02:43 PM
Do you have any pictures to where these fusible links are???
Old Aug 26, 2010 | 09:03 PM
Copchaser's Avatar
Unfortunately, my car is an 86.. therefore has a different wiring setup. Your best bet would be to consult a haynes book and look at the wiring diagrams there or wait for someone with your wiring setup to respond. Good luck
Old Aug 26, 2010 | 10:16 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
inside the motor there are Three 1/2 OD .440 length Nylon bushings.. you will need to order or make them they disintegrate into powder!!!
these motors are pretty tough to re-assemble if you have never taken one apart..
the two screws usually break!! I tap & replace with 1/4 stainless screws
Old Aug 26, 2010 | 10:55 PM
The motors work fine. I test them on my 1992 parts car. I just do not have power to the wires you plug the motors into. I understand that the headlight module has two orange wires that are hot at all times. I have no power to these and I can't figure out why
Old Aug 27, 2010 | 12:36 AM
88gta3508's Avatar
Engine: 231 / 383
have you checked the relay's up front passenger side
Old Aug 27, 2010 | 06:39 PM
No I haven't, do you have a picture or something they are by so I have a chance of finding them? Thanks!
Old Aug 31, 2010 | 12:03 AM
88gta3508's Avatar
Engine: 231 / 383
Check your headlight / map module 5" square box 2 connectors DS firewall, fuse able link
inside the plastic channel on the DS frame. are you sure the headlight switch is not smoked????
Old Sep 1, 2010 | 02:45 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Headlights will not come up..I've tried everything
Hello 02SLPTransAm !!
I remember something about a "taped up" diode in the headlight wiring harness underneath the dash, check to see if you have this first of all, and if you do, check it for proper operation!!
I recall this diode has something to do with the headlight door operation!!
Old Sep 1, 2010 | 09:09 AM
I have looked everywhere around the headlight module and cannot find a fusible link, maybe I am just blind!.....As far as the headlight switch goes, the plug that the switch goes into does have a connect area that looks smoked. I thought I solved the problem really quick when I found it, however it still had power to that area, so I eliminated that as the culprit.
Old Sep 1, 2010 | 09:11 AM
Any idea to what looks like??
Old Sep 1, 2010 | 09:13 AM
I want to thank everyone for your help, all of the suggestions I am getting are great. I just wish I could find the problem. It is so bizarre that they worked just fine before the wreck and then boom, no power to the headlight door plugs. I'll keep trying though.
Old Sep 1, 2010 | 08:22 PM
Hello 02SLPTransAm!!
If you have A/C, check the connection at the compressor, it has a taped up diode also!!
This is what you would be looking for, under the dash, sorry no picture, as I have Camaros, and they don't have pop up headlights...........as you know, so I can't show you!!
Old Sep 25, 2010 | 01:03 PM
Zmanx's Avatar
Does any have a wiring diagram that will show where each of wires in the 5wire plug go? I am getting a significant battery drain that seems to come from Terminal B.
Old Sep 29, 2010 | 01:36 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Here is a picture of the fuses for both headlamps. I just fixed mine today. I had the same symptom as you, so I followed the wires from the control module to here and found 1 of them blown. Next is to find out why my gauge cluster doesn't illuminate when I turn the headlamps on. Security light, e-brake light and such work though.
Old Sep 29, 2010 | 06:54 PM
Charcoalbird you are an absolute savior! I pulled both fuses and they are blown. I didn't get a chance to put another set in their place to check if it fixed it, but I can almost guarantee that it will. Thanks so much!!
Old Sep 29, 2010 | 07:35 PM
Car: 1991 Firebird
Engine: 3.1L V6
. I have had this problem for months now and searched the boards countless times only coming up with the pre-91' diagrams and pictures. If only there was a search function to find certain parts(or fuses in this case, and is year specific) with color photos like i've provided. That would make things so much easier.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
