NEED help with wiring problem
Old Aug 14, 2010 | 11:43 AM
thomas2213's Avatar
Hey guys, I have a 84 Z28 HO 5speed, while replacing the carpet I found a plug that was all taped up and opened and found this mess, there are two red wires coming up in front of the shifter, these were connected with a white wire on each and just stuck into the plug,which looks like it goes to the blue wire, I left one out but it looks like it was going to the green wire. also there is a jumper which looks to connect the yellow and purple wire. Long story short could someone tell me what all of this goes to and how to fix, the wire colors on the plug are black/white,orange/black ,blue, green, purple and yellow. thanks.
Old Aug 14, 2010 | 03:54 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: NEED help with wiring problem
Did it used to be an Auto trans car? Looks kinda like the plug that plugs into the shifter. Only guessing, a little help here?
Old Aug 14, 2010 | 04:19 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Yellow and the purple wire are for the neutral safety switch... I'm willing to bet you don't have to step on the clutch to start the car. As for your question, it is the plug that would go into an automatic shifter assembly.
EDIT: Green and blue were for the reverse lights switch.
Old Aug 14, 2010 | 09:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Neutral safety switch for a automatic transmission car. Two large wires for the ignition (so won't start unless in N or P. Reverse lights also. Also a wire to the trunk release so you can't 'pop' it while driving.
Old Aug 14, 2010 | 10:31 PM
thomas2213's Avatar
Thanks for the help guys. Almost done with the interior. Will post some pics when done. Again thanks for the help
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
