No power to almost everything!! help!
Old Aug 17, 2010 | 03:29 PM
themanricky1117's Avatar
Car: 1989 Pontiac Firebird Base T Top
Engine: 305 V8 carb
My 1989 firebird had a bad neutral safety switch so i would have to start it by jumping the 2 wires by the shifter. However I think one of the wires touched a piece of metal that was grounded and shorted out. It blew 3 fuses so i replaced them with the same kind. now, one headlight motor is always spinning, the horn sometimes works, and the lights work. But thats it. there is no power to anything else at all. help!!!!
Old Aug 17, 2010 | 03:52 PM
Engine: 305 V8 carb
Re: No power to almost everything!! help!
somebody plaeseeee
Old Aug 18, 2010 | 11:43 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power This Hour
You probably blew a fusible link near the battery.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe all the links and replace any bad ones you find.
They look like plastic one-inch cylinders in line with the wires.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
