NEW CHASSIS WIRING HARNESS FOR OLDER ENGINE????
Old Sep 10, 2010 | 11:37 PM
Drone358's Avatar
Hey guys, need a new complete wiring harness for my 92 RS. Putting a carbuerated engine in it and need a new harness... any suggestions. Thought maybe Painless Harnesses but don't know if they have specific car options... please let me know.. Im worrying
Old Sep 10, 2010 | 11:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: NEW CHASSIS WIRING HARNESS FOR OLDER ENGINE????
If you are carbing, all you need is the driver side harness - everything on pass side is solely ECM wiring which you won't need. The Painless is PAINFUL on the wallet from what I understand - I'd check local JY for a harness first.
Old Sep 11, 2010 | 01:23 PM
Drone358's Avatar
Okay, ya thats right, now does that come with the headlight harness also.. had this car stored for years and now i think rats chewed up my damn wiring for the headlights and everything
Old Sep 11, 2010 | 01:25 PM
Drone358's Avatar
and also id like to see a pic of ur car.. also wondering how thos Bilstein shocks n sruts handle?
Old Sep 12, 2010 | 12:52 PM
Car: 1992 RS
Engine: Carbed 350
Yes - all basic functions are on the driver harness, including lights and everything - pass harness only had computer controlled stuff. All guages and everything will work fine with only driver side harness.
The Bilsteins and the Eibachs I really like alot. With all new front suspension (tie rod ends, ball joints, etc.), the wonderbar, & the strut tower brace - it all rides really well.
Here's my photobucket link - can see some of my pics there: http://s287.photobucket.com/albums/ll121/jw_baum/92RS/
Old Sep 13, 2010 | 08:05 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the driver side harness (C100) is actually 2 connectors clipped together. one is for the headlights and the other is for guages/fuses/etc. many of the wires can be removed if all emissions and sensors are being done away with
Old Sep 16, 2010 | 08:35 PM
Drone358's Avatar
okay, hmm my next question is does it provide the wiring for a distributor? Ofcoarse im puttting an aftermarket MSD in it, so im jus wondering? I'll be buying the harness this weekend
Old Sep 18, 2010 | 02:22 PM
Drone358's Avatar
Also the C207 connector, having trouble thinking where this should go or be used??
Old Sep 19, 2010 | 10:48 AM
Car: 1992 RS
Engine: Carbed 350
Like I said, everything you need is on the driver side harness if swapping to carb - the pass side harness is only ECM functions which you'll no longer need.
May I suggest leaving the pass side harness in there, and just tucking it into the fender where it's unseen? I did this, and I use those wires all the time - it's an unlimited source of wiring that already runs from inside to outside - I use them for fan switches, fog lights, underhood lighting, TC lockup - alot of stuff - it's great having all thise wires to utilize instead of running new wires through the firewall all the time.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
