Low voltage/alt not charging battery. HELP!
Old Sep 21, 2010 | 04:56 PM
AHerrin's Avatar
Car: 1986 IROC-Z Camaro
Engine: 355 Small Block
Hey guys i'm in need of some dire help. I recently swapped my stock 305 TPI in my 86 IROC for a 355 carb, and now my volt gauge reads very low voltage. It usually was running perfect at 13 volts, but now everytime i run it, it wont go above 8 volts, and when i drive the car around, the volts get lower and lower and all the lights in the interior as well as all the outside lights get extremely dim as well, thus eventually making the battery go dead and i have to recharge it when its in the garage. For some reason the alternator will not charge the battery back up and i went to the local o'reilly's to test the alt and it passed with flying colors...Any ideas???? HELP!!!!!!
Old Sep 21, 2010 | 06:52 PM
Ice cold spit's Avatar
Car: 91 Camaro
Engine: 383 carbed/headers/nitrous
Transmission: th400
Axle/Gears: Chevy 12 bolt w/411 gear
Re: Low voltage/alt not charging battery. HELP!
I had this same problem when I changed my tbi to carburated setup you have to be sure you have the right altenator the best way to be sure is to just order a one wire hook up or maybe find a kit to swap your current over to a one wire hook up that's how I fixed mine and it's worked perfect every since
Old Sep 23, 2010 | 10:53 AM
AHerrin's Avatar
Sweet thanks a bunch! Do you know where I can attain a conversion kit?
Old Sep 23, 2010 | 10:48 PM
Car: 91 Camaro
Transmission: th400
Summit or jegs should have one but worst case scenario buy a new 1 wire hook altenator and you will definitly be good to go
Old Sep 23, 2010 | 11:14 PM
Car: 91 Camaro
Transmission: th400
327IROC85
Sep 23, 2015 12:11 AM
camarohelp
Sep 22, 2015 03:19 PM
Johnoooooo
Sep 22, 2015 08:55 AM
J.C. Denton
Sep 21, 2015 04:23 PM
abrilnelson89
Sep 16, 2015 02:19 PM
