can i use this for the fan switch??
Old Oct 15, 2010 | 12:22 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I have two knock sensors but no fan switch. Can I just crimp the knock sensor into the fan switch? They look like the same connector just different colored wires.
Old Oct 15, 2010 | 12:38 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: can i use this for the fan switch??
Do you not have a fan switch module or provision for one on the passenger side head?
I dont suggest you tie the knock sensor (on the block) to the ground activated fan switch. Keep the two seperate. They are intended to work independently of each other for their own purpose.
Old Oct 15, 2010 | 02:13 PM
0pyders's Avatar
what i mean is that the pigtail piece for the fan switch is broken off and I have a spare pigtail for the knock that I wanted to know If i could just use that to replace it with.
I went to the junkyard but they had no 3rd gen firebirds or camaros there . so I looked on other cars with v8 chevys and I could only find the blue knock sensor on them.. so I got one of those just incase it could work.
Old Oct 15, 2010 | 02:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It should work
Old Oct 15, 2010 | 02:50 PM
0pyders's Avatar
ok I'll give it a try then.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
