battery dies overnight? Unless unhooked.
Old Oct 24, 2010 | 02:50 PM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
Since getting my car back from the body shop, my battery will not keep charge overnight unless i unhook the neg terminal.
Not sure if it is something they did, or just something else. I was thinking maybe something to do with the hatch motor? maybe they didn't hook something up right back there when they put the tail lights back in. Any suggestions ? something to look for or have checked out?
Thanks much!
Old Oct 24, 2010 | 06:52 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: battery dies overnight? Unless unhooked.
You can do a parasitic/current draw test. You need a volt/ohm meter thats able to read amps. Unhook the positive cable and hook the meter inline with the cable and battery with it on the amps setting. An average reading shouldnt read any more than .05 amps. If it reads more than that, start removing fuses till you you see a drop on the meter. That will tell you what circuit is causing the draw.
Old Oct 24, 2010 | 07:00 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
do you have an audio system in your car?
Old Oct 24, 2010 | 07:05 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
see this thread https://www.thirdgen.org/forums/elec...eps-going.html hope it helps
Old Oct 24, 2010 | 09:38 PM
Rons91Bird's Avatar
Nope! Not yet ..
Old Oct 24, 2010 | 09:40 PM
Rons91Bird's Avatar
Thanks i'll try that. I have a friend at work that plays with an Ohm meter all day.
Old Oct 24, 2010 | 09:41 PM
Rons91Bird's Avatar
Originally Posted by irock88
Thanks for your input guys!
Old Oct 24, 2010 | 10:03 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Even simpler than an Ohmmeter is this old school open circuit check. You'll need the following.
1. A license plate light replacement socket(or something similar you find at an automotive repair store) with a two wire pigtail.
2. A bulb to fit in the pigtail you buy.
Disconnect your negative battery cable, attach one wire to the negative battery post on the battery, and the other wire to the negative battery cable thereby completing the circuit.
If you have an underhood light take it out and make sure all your other accessories are off.
If the light illuminates with everything turned off you have a constant draw somewhere.
You then pull fuses until you see the light turn off and depending on where you pulled the fuse from you have identified the faulty circuit, ie accessories, fuel pump, etc...
Hope that helps, I know it worked for me... I ended up finding out my ECM was faulty and sending a constant signal to the IAC valve subsequently draining my battery in 4-5 days.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
