gauge lights off when they should be on
Old Oct 24, 2010 | 07:57 PM
derek2493's Avatar
Car: 86 trans am
Engine: 305... for now
Transmission: automatic.. about to be overhauled
Axle/Gears: stock
i will be impressed if any body gets this. i stopped at a gas station to get gas. when i get back in the car and flip the lights back on. the head lights come up and the exterior lights all function normally but the gauge back lights dont come on. i both turn singals still flash on the inside, and the brights light stays on like normal too. i changed the dimmer switch and the headlight switch, checked all the fuses....now what?
Old Oct 25, 2010 | 11:53 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The First Impression Is The Lasting Impression
With the lightswitch in the “parking lights” position, use a voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe both sides of the INST LPS fuse while turning the dimmer control back and forth.
Is there power on both sides?
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Oct 25, 2010 | 05:05 PM
derek2493's Avatar
Car: 86 trans am
Axle/Gears: stock
Re: The First Impression Is The Lasting Impression
but i changed the dimmer switch??
Old Oct 25, 2010 | 06:56 PM
primaryfitness's Avatar
Car: 1989 Formula 350
Engine: 5.7l
Transmission: auto
Axle/Gears: BW 9 bolt w/3.27 gears
I have the exact same problem with my 1989 Firebird and have yet to figure it out. Let me know if you figure it out.
Old Oct 26, 2010 | 08:57 AM
NINÅ's Avatar
Transmission: 765R4
Testing, Testing, Is This Thing On ?
Yes you did.
Now it’s time to diagnose.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 26, 2010 | 10:10 AM
derek2493's Avatar
Car: 86 trans am
Axle/Gears: stock
Re: Testing, Testing, Is This Thing On ?
ok? so any ideas? if its not the dimmer switch then what else should i check?
Old Oct 26, 2010 | 11:27 AM
karr1988's Avatar
Car: 1988 Camaro
Faulty ground, maybe rust has built up where the grounds meet the body???
Old Oct 26, 2010 | 12:08 PM
NINÅ's Avatar
Transmission: 765R4
Did you perform the test in post #2?
Happy Racing!
Old Oct 26, 2010 | 12:52 PM
derek2493's Avatar
Car: 86 trans am
Axle/Gears: stock
yes the amps move when i move the switch.
Old Oct 26, 2010 | 01:56 PM
NINÅ's Avatar
Transmission: 765R4
OK you have a broken connection between the fuse output (gray wire) thru the dash connector with a possible cracked trace on the dash circuit board (the hairline cracks can be difficult to see).
Bad grounding has a lower probability because there is more than one ground involved therefore at least one bulb would illuminate if a ground went bad.
(Wire colors are subject to change year to year.)
Happy Racing!
Old Oct 26, 2010 | 04:51 PM
derek2493's Avatar
Car: 86 trans am
Axle/Gears: stock
Re: gauge lights off when they should be on
where would the wire be grounded?
Old Oct 27, 2010 | 12:36 PM
NINÅ's Avatar
Transmission: 765R4
Ground 2 A Halt
The black ground wires come out of the dash connectors and go to the ‘Convenience Center’ bracket.
The ‘Convenience Center’ is located behind the knee bolster.
The ‘Convenience Center’ contains a flasher among other parts
(just to help you identify it).
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Old Oct 27, 2010 | 07:48 PM
derek2493's Avatar
Car: 86 trans am
Axle/Gears: stock
ok. fixed it
this is located above the "convenience center" when i unplugged this. i pluged a volt meter into the ground and the one next to it. then when i flipped the switch the lights came on. i basically then made a fuse to put in to connect the wires with out hard wireing or cutting. the lights turned on but did not move when i moved the light dimmer switch. i then wondered why i needed such a stupid part if i didnt need it.,, then i tried to start my car.. REPLACE THIS PART DONT HARD WIRE. OR YOU WILL GET STRANDED. idk wht this part is called though.
Old Oct 28, 2010 | 10:37 AM
Engine: 5.7l
Transmission: auto
I think that is the interior light dimmer switch. Gonna try to replace that on my car and see if that fixes my problem as well.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
