Hatch area wires??
Old Oct 28, 2010 | 06:34 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Hatch area wires??
Wondering what these plugs are for. On group has two plugs. Orane wire coming into it with a white wire going into a second plug which in turn has a ground wire. Another plug has a pink and white wire, white, and brown and white along with a ground wire. They are currently not hooked to anything and was wondering what they are for
Old Oct 28, 2010 | 06:41 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Re: Hatch area wires??
Can you post pics of the wires for further clarification?
Old Oct 28, 2010 | 07:08 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I don't know how to. The wire are all by the hatch release. Looks like at one point in time they pluged into somthing. But I don't know what
Old Oct 29, 2010 | 02:01 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You could at least provide what year and model car.
Regardless, it's not uncommon for harness plugs/wiring to exist where options were never added. Could be for a hatch light or pull down motor that was never installed.
Old Oct 30, 2010 | 02:04 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
85 z28.
Old Oct 31, 2010 | 12:13 PM
deadbird's Avatar
Engine: TPI 305/ v6
The orange, white & black group would most likely be for a hatch light the car never got. The pink/white would probably be for a hatch pull down motor. The rest may be for power hatch release if your car isn't equipped with it. That's the best guesses I have.
Old Oct 31, 2010 | 12:59 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
The lights make sence. I am sure they were there at one point of time. PO took out a lot of trim and stuff. The hatch pull down? Did they have that in 85. I do have poer release. It works
Old Oct 31, 2010 | 01:11 PM
Drew's Avatar
The pull-down wasn't around until 86... I really wouldn't want to guess what exactly they're for without a pic... Generally Orange is 12v constant, White is the domelight circuit, and Black is a ground. If the white wire is grounded anywhere in the car all the courtesy lights will come on. Orange is usually used as a power wire for those lights. There's a pretty good chance they're for a trunk compartment light.
Street Lethal
Apr 30, 2019 12:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
