key wont start my car
Old Oct 29, 2010 | 12:29 AM
solin777's Avatar
Car: 91 Formula Firebird
Engine: 305 tpi
I installed a new colum in my car and put a older gm key cylinder in it and got the chip to delete the vats system. the car was a stolen recovery so the wires under the dash got hacked some i tried to straighten them out the best I could. the key wont start the car only when I jump the starter with a jump wire I dont know if there is some wire cut or what I dont know where to begin with trouble shooting it
Old Oct 29, 2010 | 12:38 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: key wont start my car
There's a starter enable relay, usually under the driver kick panel, under the black goo where the hood release is. You can straight wire it, or simply give it a ground.
It will have a large red wire, small yellow wire, large yellow wire, and a black wire. Can jump large red with large yellow, or else provide a ground on the black.
Old Oct 29, 2010 | 01:36 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Your colors seem a touch off..
Old Oct 29, 2010 | 02:18 AM
BillyTheGoat's Avatar
Car: 1989 Trans am
Here's where the starter enable relay is. Mine has already been bypassed. If it has not been bypassed, it should have the relay where you can ground it. The ground on mine kept coming off so I just cut the wires ( big yellow & big green one) and spliced them together. The car runs, so I think i did it right
Old Oct 29, 2010 | 11:02 AM
solin777's Avatar
Engine: 305 tpi
thanks guys Ill try that today
Old Oct 29, 2010 | 12:19 PM
Car: 1992 RS
Engine: Carbed 350
Yeah, your right! It was late, and I'm really too old to be up that late!
Old Oct 29, 2010 | 06:29 PM
deadbird's Avatar
Engine: TPI 305/ v6
haha... I'm not getting any younger myself...
Old Oct 29, 2010 | 11:15 PM
solin777's Avatar
Engine: 305 tpi
I tried the jump wire and it didnt work also once i started to dig into it I realized that the fuel pump is hot wired so Im wondering if the vats delete chip isnt working or if its with the key harness. Im unsure if this has anything to do with the same problem but I hooked up the code reader and it kept telling me it lost comunication with the computer making me think this has to be something with the key switch wiring tomorrow Im going to call the guy who made me the chip and see if he has any info
midge54
Dec 27, 2019 04:14 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
92projectcamaro
Aug 6, 2015 01:20 PM
