HEAD LIGHTS AND RADIO WONT WORK ?
Old Oct 29, 2010 | 11:28 AM
86 Camaro joe's Avatar
Car: Camaro
Engine: 2.8 tune port
i have a 86 camaro 2.8 and i was driving home and all of a sudden my radio turned completely off , so i took it to where i bought it they said it was getting the12 volt power but not a constant feed power witch keeps it on all they time power .? than he relized my head lights didnnt turn on or any of the inside light dash etc wouldnt turn on
my brake lights work and my blinkers but no other lights ,
all my fuse's are good any help .....
Old Oct 29, 2010 | 11:30 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: HEAD LIGHTS AND RADIO WONT WORK ?
fusible link
Old Oct 29, 2010 | 01:44 PM
Car: Camaro
ok so i put my stock radio back in and it gets radio static but there is not light showing the station , fyi
and do i need to replace it ? im not familiar with a fusible link..
Old Oct 29, 2010 | 02:25 PM
Car: Camaro
ok i did a lil reading about them so which fuse link do you think it is ?
Old Oct 30, 2010 | 06:21 AM
Car: Camaro
? should i just test all my fusible link wires ?
Old Nov 15, 2010 | 02:53 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
I'm having the same problem on my 84, what was the problem with yours? I lost all exterior lights except turn signals and brake lights and lost my interior lights and radio. I tested the courtesy lights and came up with a short that I was assuming was a fusable link but I couldn't find the link. Where is the link located and did it fix your problem?
Old Nov 18, 2010 | 01:04 PM
Car: Camaro
yea i had a burned fuseable link under my car , my muffler burned it some how , so i replaced it and tied it down,
Old Nov 18, 2010 | 02:06 PM
84olmpcboy's Avatar
Engine: 2.8
I found my problem last night, the wires had rubbed against the engine block where the oil pan is and it went through the insulation and burned the wire in half. So I just soldered another fusable link up there and wrapped all the wires in rubber appliance tape then went around that with electrical tape to make sure it won't rub through again.
Old Nov 19, 2010 | 03:40 PM
Car: Camaro
yeaa thats what was wrong with mine to ,
glad to see you fixed it ,
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
