Water Short of power
Old Oct 29, 2010 | 08:02 PM
Apolo's Avatar
Car: Camaro 1987
Engine: V6 2.8l MPFI
Hi, i was cleaning the, i tryed to clean around the cigarret lighter so, the wet rag touched the metal of outside and the courtesy lights, radio, power door locks have no power right now, i checked the fuse panel its ok, an disconect and reconect the battery, but i had no succes, what should i do next?
Old Oct 29, 2010 | 08:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Water Short of power
There is a courtesy fuse - probably blew it.
Old Oct 29, 2010 | 08:59 PM
Apolo's Avatar
Car: Camaro 1987
i re-checekd acc 20a fuse blown, replace it, and everithing its working again thanks
Old Oct 29, 2010 | 09:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
to add, labeled as 'acc', 20A fuse. It powers a majority of non-important to running, constant +12v things (lighter, dome lights, etc.)
*oops, to slow with on screen keyboard
Old Oct 29, 2010 | 09:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Surprising that happened, considering how bad of a conductor water is.
Old Oct 29, 2010 | 11:49 PM
Apolo's Avatar
Car: Camaro 1987
Water, but dirty of dust water, ha, i think that was the cause
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
