H4 Wiring Problem!!! Please Help!
Old Nov 5, 2010 | 07:14 AM
CamaroGuru350's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7L TPIS Miniram
Axle/Gears: 3.73 Eaton Posi
So to start off, I installed H4s in my third gen with the painless wiring harness. I had no problem hooking them up or getting them installed. Everything seemed to be going great. The low beams came on, and then the high beams. However, when I switched them back to low beams that's when it went funky. The low beams worked the way they were supposed to, but the high beams remained lit. I checked voltage going from the Headlight switch to the dimmer, and I'm getting 12 volts. However, I am getting 4.7 volts from the high beam power (LT GRN) with the low beams on. I tried replacing the dimmer... Same results. I get the same readings regardless of whether the relay circuit to the headlights is plugged up or not.. So I concluded that I am not receiving feedback voltage from the relays. The only thing I have not checked is the fog lamp circuit. I am about pulling my hair out on this one! Help please!!!
Old Nov 5, 2010 | 03:41 PM
Re: H4 Wiring Problem!!! Please Help!
Well, It happened to be the only thing I didn't check... The fog lamp relay! I just unplugged it, and everything works fine now. I guess I was getting power to the headlight relay through the fog lamp relay. Problem solved!
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
