starter drains the battery really fast
Old Nov 19, 2010 | 03:23 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
when I'm jump starting the car the battery reads 11.7 volts. Then when I try to start it the starter noise gets lower until i just hear a bunch of clicks. Do I need another battery...this one's less than 1/2 a year old.
Old Nov 19, 2010 | 04:39 PM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Re: starter drains the battery really fast
What's the terminal voltage while cranking NOT being jumped ?
A good battery with a good starter should stay above 10 for 30 seconds.
Old Nov 19, 2010 | 05:03 PM
0pyders's Avatar
when i crank it it drops down to like 6 volts then 5 then 4, 3 etc. then the starter just clicks..
the instrument lights dim and flicker when it cranks.
goes up to 11.5v after I stop cranking.
I have the negative battery cable going to the bracket on my alternator. I sanded the metal it touches.
Old Nov 19, 2010 | 10:03 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
I would try taking the battery to the local auto parts store to test. It may be defective or something. And if the battery tests fine, your starter may be drawing too much amperage.
Old Nov 19, 2010 | 11:26 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
It's a bad battery. I had a duralast do this to me once, in the dead of winter. I hooked a voltmeter up and watched . 11.5 volts while not cranking. I tried to start the car and once it dropped to 7 volts I didn't go any further. IIRC, anything below 9 volts while cranking is a dead cell.
There is always a possibility the starter COULD be shorting the battery, but like has been stated a quick test at a local parts store will determine whether or not the battery is bad.
Don't let them feed you any BS either. They tried to blame the wiring in my car for the failure. I've been running an optima battery for a year now with no problems.
Old Nov 22, 2010 | 11:29 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i dont think its the battery, i have the same problem and i jumpered it with my truck battery (yukon) and it starts to try and turn over and then starter just clicks like crazy... i tried a new alt also, im thinking either refurb starter gave up or a short somewhere... someone told me to add shims that i forgot cuz the teeths have to be within tolerancewhen trying to turn fly wheel, nto sure tho, will try this weekend, anyway, thats my 2 cents.... good luck
Old Nov 22, 2010 | 06:24 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've seen people try and jump a battery with a good one and got little help. They said they tried to charge it for all day and it still wouldn't start it. I pulled off the battery cables and discovered so much crud between the cables and the dirty battery terminals that power couldn't get through. Sometimes a simple cleaning up the connection makes a world of difference. Check it out, and don't charge the battery with the cables still connected! Just sayin'
But Opyders, sounds like a defective battery
MM2Robinson
Oct 1, 2017 09:16 AM
customblackbird
Oct 1, 2015 04:30 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
Formula_88AE
Sep 3, 2015 01:47 PM
