check engine wont flash...
Old Nov 22, 2010 | 11:04 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
wassup 3rd gen family! my check engine wasnt working at all so i replaced bulb and it works but wont flash when i first put key in.. i have the factory gm srvr manual and went thru the troubleshooting process until i got to chart a-6... is says to disco grnd wire from aldl term in one step to verify a short or grnd with meter... my question is, how do i do that??? all wires going to and from ecm, aldl and etc are all hard wired.....
Old Nov 22, 2010 | 11:49 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: check engine wont flash...
there should be a connection on the other end near the ecm, connector C207. you'll want to find the pinout specifications for your model, but any connection from the ecm going to the dash should be going through there. Unplug the C207 connectors and use a continuity test between the aldl connector and the C207 connector
Old Nov 22, 2010 | 12:03 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i do have the pin out for that connector... is it on the left or right under dash?? and do i pull grnd wire from connector or snip it and reconnect?? thnx again...
Old Nov 23, 2010 | 08:25 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
is that hidden under dash or kick panel??
Old Jan 31, 2011 | 07:50 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
just an fyi, i replaced my ecm and cleaned a few connectors and now my check engine flashes and operates correctly....
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
