Spedometer stopped working
Old Nov 22, 2010 | 09:48 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Hi, I was driving down the road and my speedometer went to 0. If I hit a bump somtimes it jumps up to random speeds but only for a second or 2. After that its dead. Do you guys know whats wrong? I would really like to know my speed lol.
Old Nov 22, 2010 | 10:13 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Re: Spedometer stopped working
Also the odometer isnt reading and its a manual trans if that helps
Old Nov 23, 2010 | 01:24 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
is it electric? mines mechanical, did the same thing once. it also made a grinding noise one time on a date. but it still works... if your torque arm bushing is bad, it will bump it. and destroy the gears. but i think you got VSS
Old Nov 23, 2010 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The VSS on a mechanical speedo is on the backside of the cluster; on an electric it's located on the tail shaft of the trans. It seems that problems with the electric is fairly common. A search should turn up an abundance of information.
JamesC
Old Nov 23, 2010 | 01:51 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Ok thanks for the info. Im wanting to take the cluster out but im running into an issue lol. I feel really stupid but how do I take of the headlight ****? I have searched all over and people say to press in the button and pull it out but I cant find it! lol Thanks
Old Nov 23, 2010 | 02:15 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Sorry for the double post....again. I was driving at what I assumed to be 30 and it said 70+ and jumped all around also the check engine light isnt on. Im assuming this means its loose at the cluster?
Old Nov 23, 2010 | 05:05 PM
i dont think so. check underneath first.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
